Fuel pump,/flow question, 239 8BA
Old Jun 28, 2010 | 05:48 PM
  #31
john smith jr's Avatar
john smith jr
Yuo, Its drivin time for sure.
Thanks for the Van Pelt link Ross. I will pick up the bushing and another rod wont hurt. I did measure it and it was close.
Julie, OT,....I did my front end less the king pins and your thread on "Front end savey" was a great help.
I may put the beefy cap from the old pump on this new pump if I get to messin around and try to get it workin some early Saturday Morn.
Thanks Folks
Old Jun 28, 2010 | 07:02 PM
  #32
Julies Cool F1's Avatar
Julies Cool F1
Were the king pins ok, or did you just not want to get into it (it's pretty easy)?
Old Jun 28, 2010 | 09:47 PM
  #33
john smith jr
The pins are real tight, Actually the tie rod ends and drag links were also decent. I did shy away from the K pins but after reading your thread and others It seemed less scary. I will get them this fall.
I was so eager to get it rollin again I forgot to adjust the worm gear. while i had the drag ling off the steering arm. duh,. I will get it
I did fill the steering gear with gear oil,( it was real low,...maybe dry,) and it has leaked a bit, I will check it again and hopefully thats not a new project
Old Jun 28, 2010 | 11:40 PM
  #34
Julies Cool F1
If they're tight just leave them. If it's not broken.........!
Old Aug 28, 2010 | 11:19 AM
  #35
john smith jr
UPDATE
I took another stab at getting my mechanical pump going again,
Got a new push rod in from Van Pelt. I pulled the pump stand and climbed up on them big fenders , lookin down into the intake for the rod and I can see a stub of the rod still in the bushing and the other half/part, leaning up against the inside wall of the intake manifold..........unbelievable. I pulled both pieces out with a magnet. When comparing the old and new push rods side by side. They were the same size but the old one was bent a bit. When I put the new rod in the thru the manifold and into the bushing it had a lot less wobble so I guess the bend is what made it seem like the bushing was worn . I put the Pump on the stand,....set the stand/pump in place, bolted it down, hooked up the lines, primed it with the electric pump and it fired right up...
Thanks
Old Aug 28, 2010 | 01:14 PM
  #36
ALBUQ F-1's Avatar
ALBUQ F-1
Cool! Doesn't get much easier than that!
dananarama
Apr 23, 2025 08:49 PM
fmc400
41
Sep 29, 2023 09:46 AM
DrZoom
May 18, 2015 03:27 PM
obscurity
May 26, 2014 04:33 PM
rodymartin
Feb 23, 2014 10:42 PM
