1997 5.8 wont start
Old May 1, 2010 | 10:04 AM
tjw1555's Avatar
tjw1555
1997 5.8 wont start
Just put a motor in and cant get it to start. It will start on starting fluid or gas in the intake. checked timing and tfi. I have fuel to rail. 40 psi. I have spark to plugs. The wires to the injectors have power both wires. Any suggestions? Do I have a bad regulator not letting the fuel to the injectors?
Old May 1, 2010 | 12:25 PM
subford's Avatar
subford
The regulator is after the injectors so to speak, it maintains the fuel pressure on the fuel rail. It is like a safety valve the lifts off its seat and lets the fuel back to the fuel tank that it came from. The spring in is set to 45 PSI but has a vacuum diaphragm that will offset the spring tension and let the pressure go lower the more vacuum that is put on it.
You need to check your injectors with a noid light to see if they are being grounded.
You would unplug an injector and plug the noid light into the wiring harness plug and crank the engine. It should flash as the engine is being cranked. The computer is what grounds the injectors.
Old May 1, 2010 | 07:56 PM
tjw1555's Avatar
tjw1555
thanks for the help
had a few problems. bought a noid light, had power. Two bad injectors, a bad map and a tooth off caused it not to start. thanks for the help
derrickmauk1003
Aug 6, 2015 07:53 PM
joker67735
Sep 12, 2013 09:28 AM
will2045
1978 - 1996 Big Bronco
17
Jan 31, 2012 03:12 PM
Billy B.
1997 - 2003 F150
Sep 15, 2010 07:12 AM
hatchet
Sep 4, 2010 07:11 AM
