STUMBLE UNDER HARD ACCEL
Old Apr 30, 2010 | 11:00 PM
hedhntr's Avatar
hedhntr
06 expy with 5.4 stumbles under wot. if you ease up to speed runs smooth but if you nail its starts jerking like im running out of fuel. no cel. help
Old May 1, 2010 | 09:07 AM
97ExpGuy's Avatar
97ExpGuy
My first thought is a bad fuel injector.
Old May 1, 2010 | 09:42 AM
Moto Mel's Avatar
Moto Mel
Check the electrical connections at the injectors and also the vacuum lines, especially the elbows on the PCV hoses.
Old May 1, 2010 | 12:57 PM
alloro's Avatar
alloro
if you nail its starts jerking like I'm running out of fuel.
Replace the fuel filter lately, or is it original?
Do a fuel pressure test to make sure you're up around 45 PSI at idle. If it's below 40 PSI you have a weak fuel pump.
Old May 2, 2010 | 01:02 AM
hedhntr's Avatar
hedhntr
have not replaced the fuel filter. it does have 50000mi on it
Old May 2, 2010 | 05:02 PM
alloro's Avatar
alloro
50K? Ouch, I'd start with replacing that to see if the problem clears up.
Old May 2, 2010 | 08:04 PM
fordtech08's Avatar
fordtech08
it's only 20,000 miles past due definetly great place to start your pump might be close to death because of that
Old May 2, 2010 | 11:31 PM
hedhntr's Avatar
hedhntr
ive atempted a few times and couldnt get the sob removed. broke my plastic fuel removal tool in the process any body know of an easier way to do it. thanks
Old May 2, 2010 | 11:57 PM
fordtech08's Avatar
fordtech08
pay somebody
Old May 3, 2010 | 12:15 AM
alloro's Avatar
alloro
Yep, get the metal remover tool. It looks like this:
Old May 3, 2010 | 08:06 AM
c_hohensee's Avatar
c_hohensee
Have you relieved the pressure on the fuel system before trying to disconnect the lines?
Old May 3, 2010 | 08:39 PM
hedhntr's Avatar
hedhntr
i took the gas cap off but that was it, what else do i need to do to relieve the pressre
Old May 3, 2010 | 09:21 PM
c_hohensee's Avatar
c_hohensee
If you have a schrader valve on the fuel rail, you can bleed off the pressure there like letting air out of a tire. The down side of this is you have gas running out. The safer way is to pull the fuel pump fuse and try to start it. It should fire up and die right away. This should relieve the pressure in the line.
Old May 6, 2010 | 11:44 AM
ebexp2006's Avatar
ebexp2006
Just bought an 06 expedition w/88000 mi. on it and had same problem. Took it back to dealer they said it was the catalytic converters.They changed them then said still had same problem.Then they said the plugs were
the problem,changed the plugs and no more problems.good luck
Old May 6, 2010 | 12:24 PM
fordtech08's Avatar
fordtech08
take it back and ask why they didn't check the fuel injectors causing the problem under the recall leaking injector fouled the plug and melted cat
