Up-pipes
Old Apr 30, 2010 | 10:09 PM
bigal614's Avatar
bigal614
Up-pipes
Ok guys, another up-pipe thread. I just made a 325 mile drive and really could tell at times how much pressure that I was losing so now I need to order them "but" now the questions are which ones? Do any of them stand out? Pro's and Con's? etc. Also, install difficulty on different styles, does the turbo have to be removed? Is the ceramic really that noticable in performance?
bellowed up pipes 183787c93
"Bellowed" Up-Pipes
1999.5-03 Ford 7.3L (Super Duty / Excursion) Upgraded Turbo Feed Tubes
Ford 7.3L 1999.5-2003 Powerstroke Bellowed Turbo Up-Pipes
Riffraff Diesel: IH Bellowed Up-pipe Kit
Ford 7.3L Powerstroke Ceramic Coated Bellowed Turbo Up Pipes
Diesel Innovations - Products
Thanks for the help guys
Old Apr 30, 2010 | 11:09 PM
7.3 Rocket's Avatar
7.3 Rocket
You want International bellowed up-pipes and Clay at Riffraff will probably get you the best pricing on them. You can get them ceramic coated if you desire. It will keep more heat in the pipes instead of allowing it to dissipate.
The Ford up-pipes use a rubber crush type donut to seal them and keep them from leaking. The Internationals use a metal gasket to seal them so they'll never leak again after you install them. Once you've done them once you won't want to do them again. Fortunately once the bellowed Ih pipes are in you never need to do them again.
Old May 3, 2010 | 02:20 PM
bigal614's Avatar
bigal614
Just ordered them from Clay, Thanks.
Old May 3, 2010 | 02:29 PM
7.3 Rocket's Avatar
7.3 Rocket
No problem.
Make sure you've got PLENTY of PB Blaster or other penetrating oil on hand to soak those bolts for a while before you start the project. A heat source (ie: torch) may be a helpful tool if you've got a rust belt truck like I do.
Old May 3, 2010 | 09:35 PM
a-rod's Avatar
a-rod
Im in the process of changing mine right now, got the bellowed ones from clay at riffraff as well.
Ive got the turbo off, now I need some ambition to start on the pipes, it looks like its gonna be real enjoyable......
Old May 3, 2010 | 09:39 PM
a-rod's Avatar
a-rod
Also a good time to delete your EBPV, mine was leaking like crazy, I got it all gutted today, not to hard. And like said, soak everything down good with penetrating oil, get the clamp at the back of the turbo really good.
Old May 3, 2010 | 10:04 PM
WA.Ranger's Avatar
WA.Ranger
Here's what I'm going with the next time around. I'll get them ceramic coated too.
Old May 4, 2010 | 07:57 PM
bigal614's Avatar
bigal614
That's what I bought Ranger but I didn't have time to wait on the ceramic coated ones.
Deluxe06
21
Jul 19, 2012 10:04 PM
Bigfwt04
117
Mar 26, 2009 04:09 PM
Riffraff Diesel
Vendor Specials, Discounts, Product Announcements & Group Buys
Mar 6, 2009 11:48 PM
miller_feed
64
Jul 21, 2008 04:33 PM
luvemhot
Jan 9, 2008 12:00 AM
