New exhaust installed
Old Apr 30, 2010 | 06:50 PM
mechelement's Avatar
mechelement
I got it done today. It's a 2-1/2" dual exhaust to a big rig muffler and a single 3" out. The muffler does the balancing and it doesn't roar so the horses will still load. He said my exhaust was in HORRIBLE shape and he just torched everything off and started over. It sure seems to get up and go a whole lot quicker now.
I did notice a stream of blue smoke behind me when I first started out, but after the motor warmed up no more smoke. I never noticed it before because of the exhaust leaking all over the place. Is this common?
Old Apr 30, 2010 | 07:50 PM
johnboggs21's Avatar
johnboggs21
if it was blue smoke from a cold start, I wouldnt worry about it too much.
Old Apr 30, 2010 | 08:26 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
hey congrats! don't forget the pics and vids!
yeah,you can tell right off quick she likes to be opened up can't ya.
Old Apr 30, 2010 | 11:38 PM
Sycostang67's Avatar
Sycostang67
Cool, make with the pics!
Old May 5, 2010 | 07:18 AM
mechelement
Only a couple pics so far...
I spoke with him about the pipe being on that metal there. He said he did that on purpose to hug it as close as possible and maintain ground clearance and there won't be any rubbing. Now I'm trying to figure out where the hell all that oil is coming from. I know my passenger valve cover is leaking and I'm replacing it. I'm not sure all of that is from the valve cover though. I'm thinking front and rear main seals.
Dual in - single out big rig muffler. He said it's the highest flowing muffler he has and it's not loud.
Old May 5, 2010 | 09:26 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
That was a mistake explained away ... IMO!
An exhaust system should touch nothing except hangars.
-Enjoy
fh : )_~
Old May 5, 2010 | 10:16 AM
wreckinball's Avatar
wreckinball
holy crap, are you gonna have to drop the whole setup to get at the flywheel inspection cover? Is it touching that thing? How about vibrations or sound? That thing touching is going to wear out the inspection cover and grind away at the exhaust. I would make him fix that. Overall looks good! I will say though that the oil hitting the pipe there is probably coming from the inspection cover meaning leak somewhere in/up there. Same thing i am losing sleep over right now haha.
Old May 5, 2010 | 08:06 PM
mechelement
I've been poking around under there and it appears to be in front of that inspection cover. He told me it was fine like that. I've never seen an exhaust installed touching part of the drivetrain.
Old May 5, 2010 | 09:48 PM
FORDF250HDXLT
looking good.yeah,you don't want it rubbing anything.if for nothing else,the vibration from it will drive ya nuts.
Old May 6, 2010 | 12:46 AM
wreckinball
Doesn't matter if he "thinks" it is good. You paid for it, he should fix it. When I do exhaust for people, if something goes wrong or it isn't right, I fix it. Don't settle. Can you remove the inspection cover???
Old May 6, 2010 | 01:00 AM
peruses's Avatar
peruses
often takes a bit of a strong arm approach to get muffler shops to do right by their work, just remind him sweetly that word of mouth will make or break his business
Old May 6, 2010 | 06:53 AM
mechelement
I'll be able to get the inspection cover off, but there might be enough tension on there it'll be a bear to get it back on. I would've been happy with 1/2 - 1" gap.
Old May 6, 2010 | 08:26 AM
87crewdually's Avatar
87crewdually
As for your oil leak also check the oil pressure switch up top by the CDR. Hot oil runs pretty good and coming from the switch would run down to where you're seeing it.
Old May 6, 2010 | 11:00 AM
damac's Avatar
damac
I wonder how much oil loss this and an unsealed dipstick tube could result inbetween oil changes?
I had to take my starter out just a couple weeks ago so I could see the dipstick tube and I think it was missing a seal. So I cleaned up up and used some ultra black as others have suggested and remated it. I had to solder a hole in mine, then I heat shrunk the area close to the manifold.
We put in a mechanical oil gage last year when we got our clunker. It started leaking soon after install with a kit that said to use teflon tape. That didn't work so I am actually going out today to take it apart, put a new old sender unit with a t and a new install on the mechanical gage with paste.
The old one was leaking when we got it as well.
Old May 6, 2010 | 11:07 AM
Festus Hagen
Methanoholic
If it's pipe thread and the teflon tape didn't seal, it wasn't done correctly.
Teflon tape works better than dope (paste), Especially with oily fittings.
JMO
-Enjoy
fh : )_~
