Smog removal
Old Apr 30, 2010 | 05:23 PM
LawF250's Avatar
LawF250
Smog removal
My 92 F250 351w has all the smog crap all over it, and i have no emissions tests to pass so i want to take it off. i already took the Cat off and the pipes coming from the smog pump are just hanging there.
the question is, if i just take all of the smog plumbing crap off is that going to mess with my fuel injection and or computer.. i dont know a lot about how the whole system works but i know that i want to get all the smog stuff off if i can.
any help is appreciated
Thanks
-Greg 92 F250
Old Apr 30, 2010 | 05:30 PM
Conanski's Avatar
Conanski
Nope, it only injects air into the exhaust at cold start to help the cat burn off the excess fuel, otherwise it's just along for the ride and has no effect on the engine. Take it all off except for the air pump(use it as an idler.. you could even gut it so it's not blowing air) plug the holes in the manifolds, but leave the TAB and TAD solenoids beside the coil electrically connected(remove or plug the vacuum lines on these though.)
Old Apr 30, 2010 | 05:43 PM
LCAM-01XA's Avatar
LCAM-01XA
What he said - as long as the solenoids are plugged in, the PCM will be happy. Do not get too industrious tho and toss the EGR out too, this one you actually need, and the engine works better with it than without it.
Old Apr 30, 2010 | 07:08 PM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
Set it all aside incase you sell it. The crap can get $ to replace. Just cause you don't need the emission test doesn't mean the next guy won't.
Old Apr 30, 2010 | 07:10 PM
LawF250's Avatar
LawF250
Great! thanks for the help, now i have a weekend project and I wont have to look at all that junk every time I open my hood!
-Greg 92 F250
Old Apr 30, 2010 | 08:12 PM
LCAM-01XA's Avatar
LCAM-01XA
Brian has a good point, keep that stuff in a box somewhere in the garage or shed. Also it ain't so much for the looks, as it is about all the space removal of that stuff opens up, you know, like for reaching sparkplugs for instance.
Old May 1, 2010 | 12:01 AM
LawF250's Avatar
LawF250
Very good point. I think i remember that crossing my mind last year when i was changing spark plugs.
Also, does anyone have a picture of what the TAB and TAD solenoids look like, i am kind of new to the whole fuel injection thing and I am not too sure what you are talking about.
Thanks for all the help
-Greg 92 F250
Old May 9, 2010 | 09:34 PM
91edbronco's Avatar
91edbronco
my air pump seized can i just pull the hose off the pump and cap it. Then just get a shorter belt to route without including the pump or do i need to pull and plug all the vacuum lines and the crosstube on the back of the motor. thanks
its a 91 bronco 302
Old May 9, 2010 | 10:21 PM
blacklab1's Avatar
blacklab1
I tossed the air pump with the rest of the smog stuff. Got a shorter belt all is well.
Old May 9, 2010 | 11:16 PM
91edbronco's Avatar
91edbronco
did you remove the crosstube on the back of the motor. I dont really want to remove everything if i dont have to. thanks for the reply
Old May 9, 2010 | 11:24 PM
CowboyBoots's Avatar
CowboyBoots
I pulled all the smog off my 91 Bronco before I traded her. Unfortunately when I did that I didn't know I'd have to get a smaller belt... Yeah, total blond moment. Schucks had to special order the size belt I needed and quoted me something like $80 for a darn serp belt. Did some jimmy riggin and found a fun way... convert to carb! Heh. Plan on removing the smog on my F150. Can't stand all that crud.
Old May 9, 2010 | 11:35 PM
rossijd's Avatar
rossijd
Thanks
-Greg 92 F250
If your going to do away with all the other crap, take the pump off too! Lose some weight and gain some power with a short belt. Just my 2 cents.
I am in process of swapping engines in my truck. I was contemplating getting rid of all the smog stuff as well. I don't have to do a smog test either, but you never know when they may start. Don't throw anything away!
Old May 10, 2010 | 01:36 AM
86F150302's Avatar
86F150302
Take the whole pump off and run a shorter belt.
Old May 10, 2010 | 05:45 AM
lew52's Avatar
lew52
I would remove the whole pump , but if you run the truck at higher RPMs i would use a FR idler pulley in place of the pump ....Lew
Old May 10, 2010 | 09:13 AM
Conanski's Avatar
Conanski
See here.. TABTAD1 on Flickr - Photo Sharing!
