99 Expy Horn Button
Old Jan 30, 2003 | 03:56 PM
hokiebob's Avatar
hokiebob
99 Expy Horn Button
I have a 99 Expy EB with what I believe to be a horn button problem. The horn only works if you hit the little horn logo on the steering wheel-anywhere else it won't work. The operative spot is only the size of a 50 cent piece or so-one on either side. I believe there must be a problem, but want to hear from folks that have had one for a while.
thanks
Old Jan 30, 2003 | 04:51 PM
jamyboy's Avatar
jamyboy
99 Expy Horn Button
Mine does the same thing........at least you cant accidentally honk at anyone! I guess it's one of those built in problems......good luck.......
Old Jan 31, 2003 | 10:47 AM
hokiebob's Avatar
hokiebob
99 Expy Horn Button
Thanks-do all 99 EXPY's have this built in problem?? Seems like the NHTSA wouldn't like it if they did.
Old Jan 31, 2003 | 11:59 AM
mneblett's Avatar
mneblett
99 Expy Horn Button
I have an '03, but I believe the wheel's the same as yours.
There are two primary approaches to horns on vehicles with airbags.
My (non-Ford) car has the airbag bolted to a spring-loaded mechanism/horn contact mount behind the bag. This approach lets you press anywhere on the air bag to cause the whole bag to move and sound the horn.
The other approach is to place contacts for the horn directly under the outer skin of the airbag assembly. With this type of bag, you have to press on the bag face directly on (or at least near) the horn contacts under the bag skin to get the horn to activate. That's what's in my '03. Certainly not as convenient/fast when you want to blow the horn NOW, but an "acceptable" design from DOT's point of view.
Old Mar 16, 2003 | 09:56 PM
Tom Pom's Avatar
Tom Pom
99 Expy Horn Button
My 1999 F250 SD has the same useless horn button.
The sweet spot is dime sized and below the horn icon.
Try to find it in a hurry. I havn't found that first one that works if you push with the palm of your hand. Finger poke yes.
Ford has no fix and Ford Customer Service says if the horn blows there is no problem. I filled a complaint with NHTSA and would recommend that all who have this problem do the same.
The contact is part of the airbag assembly $$$$
I drilled the wheel spokes and added 2 push switches from Radio Shack and wired them to the horn connection under the air bag. They are where your thumbs comfortably reach.
All the wires are hidden and now I have a piece of saftey equpment that is more important than a airbag.
If anyone wants pics just ask.
Old Mar 17, 2003 | 08:57 AM
99ExpyOh's Avatar
99ExpyOh
99 Expy Horn Button
I was noticing this very thing yesterday on our 99 Expy. I was thinking of applying something to the sweet spot areas so that you could find them by touch.....but at the same time I wouldn't want it to ruin the appearance.
What a dilemma....
Old Mar 17, 2003 | 11:25 AM
Tom Pom's Avatar
Tom Pom
Lightbulb 99 Expy Horn Button
Keep in mind that the last place you want your hand to be if the air bag deploys is over the horn pad.
How's that for a catch 22.
rzns60
Sep 12, 2020 12:02 PM
bigred22769
Mar 18, 2019 09:40 PM
stang9090
Sep 24, 2015 04:00 PM
Snapper3
Nov 9, 2012 03:42 PM
vwhed1979
Aerostar
Jan 20, 2006 11:24 AM
