what is this?
Old Apr 30, 2010 | 07:28 AM
ad326's Avatar
ad326
what is this?
ok stupid newbie question here!! There is what looks like a fuel line(about1/2in) running down beside my frame rail and has what looks like some sort of filter canister and it runs back to the fuel tank, is this like a bypass filter or what and what do i do when servicing my truck, I will try and post pics. Sorry its a 2000 7.3 ok pic is in my album!!
Old Apr 30, 2010 | 07:32 AM
Izzy351's Avatar
Izzy351
A pic would help, but the fuel pump is mounted just under the driver-side door on the frame...
Old Apr 30, 2010 | 07:36 AM
ron's power stroke's Avatar
ron's power stroke
does that line end right at the so called filter?? sounds like a check valve for the vent....
Old Apr 30, 2010 | 07:38 AM
ad326's Avatar
ad326
no it goes back to the tank and the canister is white and has a screw off drain plug, trying to post pics but having some issues!!! It is not really a canister but like pvc also has the name ASCO wrote on the drain plug
Old Apr 30, 2010 | 07:51 AM
Izzy351's Avatar
Izzy351
You need to put the pic in your gallery or on a photo sharing site like WebShots or PhotoBucket...
Old Apr 30, 2010 | 08:00 AM
ad326's Avatar
ad326
pic
picture is now in my album!
Old Apr 30, 2010 | 08:05 AM
Izzy351's Avatar
Izzy351
That's really strange. Can you follow the lines from both ends to see where the lines terminate for sure? I'm thinking some kind of home-made CCV catch, but it's pretty small for that.
And so everyone doesn't have to go in his gallery, here's the pic:
Old Apr 30, 2010 | 08:06 AM
clux's Avatar
clux
That's a blurry picture, but i think it's some sort of a homemade ccv canister. Where does the other end of the hose go?
Old Apr 30, 2010 | 08:11 AM
F350-6's Avatar
F350-6
Pull the plug and see what comes out. CCV would be a good guess.
Old Apr 30, 2010 | 08:13 AM
ad326's Avatar
ad326
thanks
Thanks Izzy for posting that ok i just checked again and the line stops in front of the tank and is not attached to anything, just open So there is like a big mess back around my tank and on frame rails!! BTW this canister is leaking as you can see, I guess I will trace where it comes from
Ponyboychris's Avatar
Ponyboychris
Follow the rubber line back into the engine compartment. CCV is also my guess.
Old Apr 30, 2010 | 08:14 AM
clux's Avatar
clux
It's a ccv line, it should go to the little housing on the rear of the drivers side valve cover.
Old Apr 30, 2010 | 08:17 AM
ad326's Avatar
ad326
THat is where it goes, do I do anything with it when servicing my truck? And what is CCV?
Old Apr 30, 2010 | 09:16 AM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
Crank Case Vent
Old Apr 30, 2010 | 09:25 AM
N V US Lawn Care's Avatar
N V US Lawn Care
Yeah, it looks like the PO did a CCV mod to your rig, but i'm not sure why that little bitty canister is even there, it has no media in it to catch the oil residue, unless that drain plug is pulled off the canister, it serves no purpose...IMHO, just take that thing off and let it vent to the atmosphere and get a vacuum plug from Advance Auto for the (not sure what it's called) place where the hose reconnects to the air intake tube...you can get a pack of various sized rubber vacuum hose plugs there for $2.89...i just bought a pack on Tuesday...
I will go get some pics for my gallery so ya'll can see WTF i'm talking about...lol
