rear end issues
Old May 10, 2010 | 08:20 AM
TxFordGuy's Avatar
TxFordGuy
Is there any cause of these bearing issues? not changing oil often enough? wrong type of oil?
What oil are most of you out there using? i changed mine out with Royal purple. was told you don't have to add the friction modifer when using that. is that true or do i still need to add some?
Old May 10, 2010 | 10:08 AM
mueckster's Avatar
mueckster
Most people seem to have good luck with RP, but a buddy of mine has burned up 2 burned up the bearings in 2 differentials twice, in the same 2 company trucks, and has seen the this oil break down in the final drives of his mini excavator. Maybe his bad luck, but I won't use it. I am currently using Mobil 1 full syn 75w-140, but with no additives since I have an Eaton True Trac.
Old May 10, 2010 | 04:10 PM
Waynenap's Avatar
Waynenap
I'm getting ready to do my rear end and priced out the mobil 1, almost $19 a quart at advance. Any body know of a better price, anywhere?
greentruck72
20
Aug 5, 2016 07:30 AM
Lobanz
May 30, 2016 03:15 PM
Island'r
Sep 29, 2014 07:13 PM
eaglesfanguy
Sep 30, 2010 12:18 AM
Big90250
Aug 11, 2004 10:14 PM
