Overdrive
Old Apr 28, 2010 | 07:10 PM
Jason Lewis's Avatar
Jason Lewis
Overdrive
How many of you guys use OD? I only use it on Hwy travel i never use it in city travel i cant stand the fealing it gives when it pics gears when OD is on durring city driving. The only other time i dont use OD is if im driving on Roads that have a lot of hills like Central texas my truck climbs those hills much better in 3rd. 141,000 on my 4r70w
Also when i was towing alot i keep the OD off !
Old Apr 28, 2010 | 07:26 PM
zxwut?'s Avatar
zxwut?
I have a E4OD. I never turn overdrive off. No need to.
Old Apr 28, 2010 | 07:43 PM
Bayer-Z28's Avatar
Bayer-Z28
^ x2.. but with a 4R70w (or 75.. no idea) I only turn it off when I'm driving up a lot of hills, or when I am getting off the HW. Works good as a small downshift.
Old Apr 28, 2010 | 08:12 PM
Jason Lewis
4r7ow i do the same !
Old Apr 29, 2010 | 05:12 AM
TexasGuy001's Avatar
TexasGuy001
I only turn the OD off when towing moderate or heavier loads or in areas with alot of hills.
Old Apr 29, 2010 | 07:44 AM
truckrider814's Avatar
truckrider814
I only turn the od off when, towing, about ready to burn out (learned the easy way from a friend with an aod that learned the hard way), hills, or when the weather sucks and makes the truck bog down. i don't have a problem with it shifting cause i make it shift when i want it to.
mblaksley
Nov 3, 2011 07:01 PM
K_and_I
All Things Towing
Aug 1, 2011 11:12 AM
redbug
Aug 2, 2010 12:29 PM
rtpalin
1997 - 2003 F150
May 12, 2008 08:08 PM
bighoss550
May 5, 2005 10:08 AM
