6 spd auto?
Old May 3, 2005 | 06:23 PM
bighoss550's Avatar
bighoss550
6 spd auto?
when coasting down a hill i often knock the lever into "N" because of the deep gearing in my truck. when i get to the bottom, and drop it back to OD, the truck shifts into a ghost gear and raises to about 1500rpms for just a second before jumping back into OD(5).
i could only WISH there was a double OD 6th gear and id have no problem forkin over a grand or more to have a progremmer that makes use of it!!!!!
just thot id ask in case
Old May 3, 2005 | 07:13 PM
tiredlr's Avatar
tiredlr
6 Speed Auto
Bighoss I Understand The 5r110 Torqueshift Has An Extra Gear Thats Only Used On Downshifts....hence.. Truly A 6 Speed But Not Advertised As Such..btw Hows The Water/meth Set Up..ever Instlall It?
Old May 3, 2005 | 07:31 PM
mlb4966's Avatar
mlb4966
I saw somewere on the internet, wish I remember were, that shows the shift pattern for the TQshift. Its a 6 speed and uses 5 up and 5 down but not the same 5.
Old May 4, 2005 | 06:34 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
1-2-3-4-6 pattern
1-2-3-5-6 pattern
It is a six speed but never use more then 5
Old May 4, 2005 | 06:42 AM
KurtNJr's Avatar
KurtNJr
On a cold morning when taking off and building up speed slowly you can count all six of them. Use a fairly light and steady throttle - it will shift 5 times.
Old May 4, 2005 | 07:09 AM
Casey's Avatar
Casey
That fifth shift is the torque converter locking, not the 6th gear.
Old May 4, 2005 | 07:17 AM
KurtNJr's Avatar
KurtNJr
Casey - watch the tach on the last shift.
Old May 4, 2005 | 07:26 AM
bighoss550's Avatar
bighoss550
the last one is the lockup, but i was wonderin about somethin on past that.
guess im gonna hafta steal the WDS from the dealer and figger it out!!!
Old May 4, 2005 | 03:33 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
If the tranny is in cold shift mode, it will utilize all 6, and the converter will not lock up until in overdrive. Its conditional on 75 degree fluid and time delay...it usually doesn't stay on too long.
Old May 4, 2005 | 04:29 PM
jackofalltrades's Avatar
jackofalltrades
I kin git five up or down shifts with the ZF6 when I want. And I don't haf to worry when the tork converter's gonna lock up. No matter what the temperature is.
Old May 4, 2005 | 07:07 PM
TheDuke's Avatar
TheDuke
So 5th is a down shift gear only?
BTW you guys need to learn to use spell check...
Old May 4, 2005 | 11:01 PM
mlb4966's Avatar
mlb4966
Will it use all 6 in Tow/Haul mode? Going up or down.
Old May 5, 2005 | 06:32 AM
KurtNJr's Avatar
KurtNJr
PSD 60L FX4 - Matt - thanks for confirming my reported experience of the six speed auto using all six when cold. I would like to say it proves I'm not crazy but that would be going too far - all it proves is that I can count! Kurt
Old May 5, 2005 | 08:43 AM
bighoss550's Avatar
bighoss550
if it were using 6 gears when cold or anytime, u would count 6 rpm changes. that would be 6 gears and one lockup.
the last rpm change u see is the lockup. it seems like a gear change but its not.
i was asking if anyone knew what i was experiencing.... try it sometime and ull see what im talkin about, but i think u all will have to be going about 85 to get the rpm's up enuf to notice it
Old May 5, 2005 | 08:47 AM
bighoss550's Avatar
bighoss550
its been installed for a while..... its awesome. its the best thing ive ever done on a vehicle. as long as i have wwf in the tank, the truck almost never loses speed on the interstate, no matter how much im pullin!!!!
