#1 Fuel Pump problem?
Old Apr 28, 2010 | 04:58 PM
blue92f150's Avatar
blue92f150
Question #1 Fuel Pump problem?
I have a 92 and it refuses to run off the front tank. Runs fine off the rear tank, but not the front. Funny thing is that I can "hear" the front tank fuel pump priming the fuel system (whirring sound, just like the sound from the rear tank pump) before I attempt to start, so the front tank fuel pump "appears" to be somewhat functional.
So, question is what ELSE could possibly be the problem (assuming the front tank pump is fine) causing the truck to not run when switched to the front tank? Could something be clogged between the front pump and the engine?
Thoughts?
Thanks. Jim B.
Old Apr 28, 2010 | 05:19 PM
subford's Avatar
subford
The only two things it could be is a pinched fuel line from the top of the tank to the "T" on the frame or a plugged up sock on the bottom of the pump.
But I will vote for a bad pump.
Old Apr 28, 2010 | 05:59 PM
blue92f150's Avatar
blue92f150
Bad Pump?
How can the pump be "bad" but still make the whirring sound?
Jim B.
Old Apr 28, 2010 | 06:11 PM
blue92f150's Avatar
blue92f150
BTW...
What is the name of the hard fuel lines that form the "T" near the mid-tank? The one line (of the three hard lines there held in by the white plastic clip) is rusty and pretty bad too. The two hard fuel lines right against the frame are OK, it's the third hard line (furthest from the frame) that's going bad. So, what is carried by that third line?
Thanks again...
Jim B.
Old Apr 28, 2010 | 09:10 PM
subford's Avatar
subford
Brake fluid to the rear wheels?
Old Apr 29, 2010 | 04:03 PM
blue92f150's Avatar
blue92f150
Nope...
The third line is definitely fuel related. Perhaps it's the vent for the two tanks? One end of this rusty line appears to go to a plastic T, one end of which goes to the top of the mid-tank. Check out the pics...
Jim B.
Old Apr 29, 2010 | 04:17 PM
subford's Avatar
subford
OK the 1992 vapor line is on the drivers side until it gets to the front tank and then it goes to the other side. Other years it was on the the other side of the truck all the way.
Old Apr 29, 2010 | 07:03 PM
blue92f150's Avatar
blue92f150
Awesome!
Thanks for the info.
Wonder if I can replace the rusty hard vapor line with plain-old rubber fuel line hose...
Jim B.
Old May 8, 2010 | 09:26 PM
Marauder2004's Avatar
Marauder2004
Could the problem that blue is experiencing be caused by a faulty selector valve?
Old May 9, 2010 | 06:40 AM
subford's Avatar
subford
A 94 does not have a selector valve.
Old May 9, 2010 | 06:43 AM
Marauder2004
Do you know what year was the last to use a selector valve?
Old May 9, 2010 | 08:34 AM
subford's Avatar
subford
The 1989 F-series gas and the 1990 E-series gas.
Of course all Diesels use them but they are motor operated.
captain1997
Apr 26, 2013 08:13 PM
lcattin
Jun 2, 2011 08:38 AM
gracjm
May 21, 2007 03:38 PM
tawd77
Feb 8, 2007 04:56 PM
winddance
Apr 9, 2005 10:48 AM
