how to pull transmission codes?
Old Apr 28, 2010 | 03:56 PM
f-250heavyduty's Avatar
f-250heavyduty
do you hook a scanner up to the plug under the hood? or is there another connection on the pack for the tranny?
Old Apr 28, 2010 | 04:35 PM
dustybumpers's Avatar
dustybumpers
hook up under the hood, and it's in the koeo codes, engine codes come 1st, then trans codes.
Old Apr 28, 2010 | 05:55 PM
f-250heavyduty
thanks alot man
Old Apr 28, 2010 | 06:05 PM
dustybumpers
if you don't have a scanner, you can hook a wire from the single hookup on the scanner plug to ground, then turn on the key, and count the flashes. starts with 1.....1, .then count the flashes 1....1....1...........1....1...would be 32 it will go through them 2 times. yours should be 3 diget codes
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
