my parents just bought a 2006 ford expedition and it did not come with an owners manual was wondering if you could tell me how to get the code to the door lock combination to unlock the expedition
I have a 2005 EXP bought used, and also 2006 250. Needed the codes for both key pads.. I believe the code is on a sticker located behind the center dash, radio area. If you look up at an angle from the drivers side floor, (use a flash light) you should be able to see it. It is pretty easy once you find it. Also, it may be upside down, There is a thread on here I think, or do a search for it on the net.
Look for a black module under the passenger side dash, next to the sidewall (kick panel) and behind a bunch of cables. It will have a white sticker on it with the 5 digit code being the larger numbers.
