HPOP
Old Apr 27, 2010 | 06:17 PM
bbier64's Avatar
bbier64
HPOP
I am taking the HPOP cover off. 8 screws around the perimeter are out. Cover is still tight. Do I have to remove the IPR also? How is the IPR removed?
Old Apr 27, 2010 | 06:36 PM
cheezit's Avatar
cheezit
there are the 8 bolts then there are 2 more that hold the heat sheild to the back of the pump cover. you dodnt say waht year the truck is so its hard to awnser if the ipr needs to be removed. if its a cast iron pump cover then ipr and cover can be taken out together, if aluminum then the ipr must come out.
the ipr is removed with an ipr socket, or a 36 mm wrench.
Old Apr 27, 2010 | 06:39 PM
bbier64's Avatar
bbier64
truck is an 05. I don't have the heat shield bolts off yet, but I expected that the cover would at least be loose. I have the IPR unplugged.
Old Apr 27, 2010 | 06:47 PM
cheezit's Avatar
cheezit
ya that cover wont just pop off. its on there very well. I use a heel bar and a 4" long 1/2" extension to remove it. the extension goes in the drain hole and then lift up on it and the cover will come up.
Old Apr 27, 2010 | 06:50 PM
bbier64's Avatar
bbier64
Thanks. Got the heat shield screws out from the bottom. I'll pry a little harder on the cover. Does IPR have to be removed on the 05?
Old Apr 27, 2010 | 07:20 PM
bbier64's Avatar
bbier64
Removed the ipr and the cover is loose. Thought I could get it off without removing the egr cooler, Is is possible to remove the HPOP cover without removing the egr cooler?
Old Apr 28, 2010 | 06:38 PM
cheezit's Avatar
cheezit
yes it is possible to remove the cover w/o removing anything but the turbo and pedistel on any truck that does not have the 03 style intake.
Old Apr 28, 2010 | 07:20 PM
bbier64's Avatar
bbier64
You're correct, but it sure isn't easy getting that cover past the egr cooler. Got the HPOP off and the STC fitting was bad shape. The hard plastic oring was shredded.
Thank you very much for all the help. I bought this truck with 220,000 miles and now has 256,000. I had an 03 duramax previously (x wife has it now) and the first time I felt the acceleration of the 6.0 powerstroke I had to have one. The stock powerstroke pulls my horse trailer and 32 ft fifth wheel with much better than than the stock duramax.
Old Apr 29, 2010 | 12:50 PM
cartmanea's Avatar
cartmanea
Cheezit, on an '03 does the intake manifold have to come off? I'm throwing another injector in mine today or tomorrow to fight a miss, but if it's HPOP problems causing it I'll be going in there with air pressure next to try and find a leak. Thanks.
Old Apr 29, 2010 | 06:25 PM
william_04_x's Avatar
william_04_x
The early style IM rear crossover is what gets you cartmanea..
Old Apr 29, 2010 | 06:51 PM
cheezit's Avatar
cheezit
[quote=william_04_x;8831222]The early style IM rear crossover is what gets you cartmanea..[/quote
correct awnser.
Old Apr 29, 2010 | 07:10 PM
adamtheman16's Avatar
adamtheman16
Does Ford use the updated STC fitting like International with the solid fitting that has to be clocked properly before it is bolted to the branch tube?
I made a couple 15/16 wrenches for tightening that fitting jam-nut since the "special tool" came up missing. Its a tight fit.
Old Apr 29, 2010 | 07:34 PM
cheezit's Avatar
cheezit
yes fored has gone to the same part. we however dont clock ours on the engine. we use a bench vise and the correct tools.
Old Apr 29, 2010 | 08:20 PM
bbier64's Avatar
bbier64
Cheezit, do you have a fixture for clocking these on the bench? I have the new fitting (International Dealer $30, Ford Dealer $54) and the pump is placed in per instructions. I only have a 6 point crows foot and couldn't get that to fit the lock nut. I'll be waterjet cutting a couple 15/16 wrenches tomorrow to fit in that tight spot.
Old Apr 29, 2010 | 08:38 PM
cheezit's Avatar
cheezit
there should have been a black plastic (abs) thing in the kit. that is what is used to clock them. so yes I do have a few of them. its also 5 turns in.
