add a leaf or spring pack
Old Apr 27, 2010 | 09:29 AM
pauljackmax610's Avatar
pauljackmax610
just bought a 96 psd f350 regular cab 4x4, has a slight rake to it. came with add a leafs but wanna do spring pack by sanderson.what does anybody think?
Old Apr 27, 2010 | 09:42 AM
Talyn's Avatar
Talyn
Cant' go wrong with new leafs in the front.
The 250' leafs are a bit more stout if you wanna go that route, not sure how it will effect ride.
I'm in this predicament too, i have add a leafs up front, and i'm raked forward more than I want as well. I want it to sit level, but I dont want to spend to much before d60 conversion.
Old Apr 27, 2010 | 10:20 AM
Brown Falcon's Avatar
Brown Falcon
New springs would be best. Add-a-leafs are good. Getting your original springs re-arched BAD!
You could get some 2" lift springs for it while you're at it. Might be worth it.
Old Apr 27, 2010 | 10:23 AM
Neal 97 250's Avatar
Neal 97 250
^^^^X2^^^^
Action4478's Avatar
Action4478
I did new spring packs ,add a leaf, & a had them re-curved to add 2 ' more lift . still a little lower in the front ,but carries the plow nicely ...
Old Apr 27, 2010 | 10:33 AM
Brown Falcon
Geez, my reputation feels inadequate whenever Neal and Rick post after me...
How many rep points do you need to get more than one green bean?
Old Apr 27, 2010 | 10:38 AM
pauljackmax610
i had add a leafs on my 94 f250 and with the ttb it was all out of camber so i got shims what a mess, so sold it got a good deal on the psd 350 and just want it to sit level, it has 315 goodyear mtrs on it with miminal rubbing but still havent spaced the bumper,anyways i seen spring packs and it looks easy to do and heard ride is good then again i ride a hardtail chopper so ride really doesnt matter,unless the women with big fake ones complain!!!!!!
Old Apr 27, 2010 | 12:49 PM
Action4478's Avatar
Action4478
If you lift it , you'll need to lengthen the track bar some , or get an adjustable one ....
Old Apr 27, 2010 | 12:51 PM
Action4478's Avatar
Action4478
If I understand it correctly , 100 for the dark ones & 150 or 200 for the lighter ones (not real sure ).. The first one is free ..
Old Apr 27, 2010 | 12:55 PM
Talyn's Avatar
Talyn
its 200 for your first green bean, and 100 after that.
Old Apr 27, 2010 | 01:51 PM
pauljackmax610
thanks for all the input im curious if a spring pack is relatievly easy to do
Old Apr 27, 2010 | 02:24 PM
RRranch's Avatar
RRranch
You do realize it's supposed to be higher in the back right? That's so your headlights don't aim at the moon when you put a load in the back.
If you change it you will regret it when you try to tow heavy with it.
Also if your front end is sagging, just take it to a spring shop. They can fix it right and usually it is just bushings. The springs almost never wear out on any of these trucks. They can be rearched with new bushings on the spring eyes and shackles for about 500 bucks on all 4 springs at most places that do leaf springs.
This will not mess up your alignment or handling either.
Old Apr 27, 2010 | 02:29 PM
Action4478's Avatar
Action4478
Around here , you would be hard pressed to find someone to re arch the main leaf. (liability issues )
Old Apr 27, 2010 | 02:30 PM
Cuda_jim's Avatar
Cuda_jim
Just gave you another. How many do you have now? It's in your User CP.
First one is free, 100 for the second one.
Read here for the Green Bean scoop from our super mod.
Scroll down to post #12
https://www.ford-trucks.com/forums/4...on-points.html
Old Apr 27, 2010 | 03:45 PM
pauljackmax610
im not gonna be towing or anything like that its just a toy, i was just curious which is better the add a leaf or spring pack
