powerstroke swap?
Old Apr 27, 2010 | 08:25 AM
Boostmonkey's Avatar
Boostmonkey
powerstroke swap?
Hi, I have a 91 F350 with the NA 7.3. The motor has almost 400,000 miles on it and is getting very tired. Instead of rebuilding it, I want to swap a newer Powerstroke into it. I can get one from a wrecked 97 e350, the motor is complete, with harness and trans for $1000. I have a very good knowledge of automotive systems, etc. It should be a pretty straight forward swap, I'm just looking for any advice, or problems with the swap, wiring, cooling, etc, thanks
Old Apr 27, 2010 | 08:43 AM
Talyn's Avatar
Talyn
Since its from a van, you'll have to swap over some parts, like intake parts and stuff, and the exhaust return parts, other than that, I believe they are the same motor, Pull them both and get to swappin.
Don't forget to put in some new GP's and exhaust doughnuts when you have it off.
If you got some money to spend, drop in some stage 2's and an h2e while your at it. haha. =)
Old Apr 27, 2010 | 09:16 AM
Boostmonkey
I have the wiring diagrams, from both trucks (ford, not chilton) so basically i just have to soldier and shrink wrap a few wires, and just run 2 dash harnes, one for the truck one for the motor. The rest should be nuts and bolts..
Old Apr 27, 2010 | 09:18 AM
Talyn's Avatar
Talyn
You should be able run the harness out of your pickup on the van engine, like i said, you gotta swap some parts out, cause they are not the same on the van. Located in different spots, or what not.
Old Apr 27, 2010 | 09:30 AM
Boostmonkey
Ill probalbly need most of the van harness, the old motor is mechanically injected, the new one is electronic.
Old Apr 27, 2010 | 09:39 AM
Talyn's Avatar
Talyn
Oh my bad buddy. I though you said you were pulling a powerstroke, not an IDI. I guess I should have read it was a 91.
I'd post this over in the IDI forum as well.
You'll have to get some doner parts from a reg PS for the conversion.
Mad van will know more about this.
Old Apr 27, 2010 | 10:02 AM
Boostmonkey
Thanks for the info, I'l repost in the IDI forum, Thanks!!
Old Apr 27, 2010 | 10:18 AM
Brown Falcon's Avatar
Brown Falcon
You'll need to use almost all of the van harness. A lot of different sensors and PCM controls on the PSD motor that the IDI doesn't have.
79 Crewcab 4x4
Engine Swaps
17
Feb 18, 2020 06:18 AM
4benjamin
Oct 16, 2013 08:35 AM
Blackdog 15
60
Sep 12, 2011 10:34 PM
CRUNKED77FORD
Engine Swaps
Mar 17, 2011 08:50 PM
NMf250
Oct 10, 2004 10:05 AM
