NP 435 conversion?
Old Apr 26, 2010 | 10:57 PM
74f2502wd's Avatar
74f2502wd
NP 435 conversion?
I have been pondering the idea of installing a 4 speed granny low in my 74 460/c6. I was wondering what bell housing i would need as well as what donor car would i get the clutch pedal etc from. Is this a hard conversion? Thanks for any info.
Old Apr 27, 2010 | 03:33 AM
tikkakoski's Avatar
tikkakoski
My buddy with a 79 429 4x4 c6 is planning on doing the same thing. He said its not hard but hes pretty handy with that kind of thing. Evidently he got all the pedals and pedal linkages from a donar at a junkyard. He also said something about needing longer rear drivelines i beleive.
Old Apr 27, 2010 | 03:50 AM
RCrawler's Avatar
RCrawler
You need a bellhousing from a 351M/400 or 460.
Jason
Old Apr 27, 2010 | 11:27 AM
74f2502wd's Avatar
74f2502wd
Thanks for the replies. So what kind of car can i get the pedals out of? Anything?
Old Apr 27, 2010 | 07:13 PM
lurch460's Avatar
lurch460
Get the whole clutch and brake pedal assemnly from a truck with a four speed. The best way to go would be to find a whole donor truck with all linkage and everything. Pretty much bolt and unbolt deal then.
Old Apr 27, 2010 | 07:31 PM
lannondiesel's Avatar
lannondiesel
I am considering doing the opposite in the next couple weeks. I have a 1978 with a 400M that has a np 435 I am going to remove and put a C6 in. Where are you located? If you want the pedals I will sell them to you cheap. Not sure what shipping would be though. If I keep this truck i will be doing this conversion by May 15th which is my first trail ride weekend. I am going to put the whole truck on ebay tonight though but I doubt it will sell.
Old Apr 28, 2010 | 11:29 PM
Bgasrickshaw's Avatar
Bgasrickshaw
Here's a link (I hope) to a thread where I listed the things I needed to swap from a C6 to a 4speed . Might give you an Idea of what's required. https://www.ford-trucks.com/forums/8...y-options.html
