need transmission help.
Old Apr 26, 2010 | 09:44 PM
scrapjunkie's Avatar
scrapjunkie
Question need transmission help.
I have a c6 transmission. i was replacing the filter and pan gasket today and when i dropped the pan, there was a piece of metal that had broken off the bolt that goes through the neutral safety switch. What is this part called and what is it's function? please help!!!!
Old Apr 26, 2010 | 10:27 PM
TheKirbyMan's Avatar
TheKirbyMan
By "bolt that goes through the neutral safety switch", do you mean through the center?
Look for a long metal rod (probably yellow in color) coming from the carburetor and going into the side of the transmission. This is the kickdown rod that makes your transmission downshift when you mash the pedal.
See if the rod can be pulled out of the transmission by hand. If it is, that might be what you've found, is part of what held the kickdown rod in. Mine can be pulled clean out of my truck's C6....and surprisingly it still works, as I found out by accident! lol
Old Apr 26, 2010 | 10:34 PM
scrapjunkie
YES!!! right through the center of the neutral safety switch. the bolt that is still in the hole has threads on it but has been hidden until today when i saw it and pushed it out. is the kickdown rod supposed to mount to the bolt that is in the center of the neutral switch? the piece of metal i found is a 90 degree elbow that broke off inside the transmission. im assuming it has been like that since i bought the truck two years ago.
Old Apr 27, 2010 | 02:34 PM
79F-1504x4's Avatar
79F-1504x4
This is where I buy all my part's for customer's rebuilds, nice interactive diagram, good prices even to the public.
https://www.wittrans.com/Schematic.a...-6&Schematic=5
Old Apr 27, 2010 | 04:01 PM
scrapjunkie
thanks 79F, that's a great diagram, i searched and searched but this is by far the best. and that part that broke off is (991-1) on the diagram. I really appreciate the help both you guys have given me.
God Bless You,
chuck
Old Apr 27, 2010 | 05:05 PM
79F-1504x4's Avatar
79F-1504x4
No problem man I need tons of help too I just offer what I can in return
79' green machine
Apr 6, 2014 03:46 PM
brwolfjr
53
Jun 28, 2013 07:11 AM
Tanner2255
40
Feb 19, 2013 09:18 AM
fl1a
Sep 24, 2010 04:45 PM
Black03F-150
1997 - 2003 F150
Feb 10, 2009 08:34 PM
