Well, along the same idea-
last summer my ujoints in the rear driveshaft gave up and flew out, completely ruining both ends of the shaft when it hit the road. When I was having a new one made I drove for 3 or 4 days front wheel drive style with a plastic bottle clamped over the 208's tailshaft. I only have one truck. Thank God for 4 wheel drive.
On the other hand you could make custom lock outs for any full floater, or get an Atlas II, it has front wheel drive only selection.
Hey, all the people who drive front wheel drive cars say they get better traction in the snow and ice anyway right? Who needs the rear wheels to drive?
MMMm....saw this done on a jeep...in i think 4wheel and off road, they did it for towing purposes. I say they should have gotten a bronco then they would be able to drive it to where they 4 wheel. LOL Later Whit
Just remember guys, front wheel drive is fine for "get home because something broke" but the front drive line was designed to work in conjunction with the rear not necessarily as a stand alone drive line. I admit I have done it for a few days while I replaced U-joints in the rear shaft but never did any highway running with just the front drive line.
But the idea has merit...imagine being able to unlock all four hubs and set the parking brake. Put the truck in drive and 4H and look for problems with both drive lines moving. you'd probably be able to pinpoint that bad U-joint or bearing pretty quickly.
Also remember that the whole reason for having a live front axle is for those times when your rear axle has so little traction it might as well BE disconnected. The front driveline is just as strong as the rear, but it's often in worse shape from lack of use, and the u-joints in the steering knuckles aren't smooth when you turn. I've towed loaded trailers in FWD when my rear axle went out.
