Sponsored by: Auxito
running rough
Old Apr 26, 2010 | 09:10 PM
chriscox1980's Avatar
chriscox1980
running rough
ive got a 2003 ford f-150 sport with a 4.2L V6 and since i bought it 8 months ago i have changed the plugs, plug cables, the MAF, the air filter, the fuel filter, the coil pack, and the IMRC. I have also run fuel injector cleaner through the engine and then later sea foam through the intake. It is still sluggish when pulling off from a traffic light, stop sign etc. The only thing that it codes is an oxygen sensor. could that possibly be the problem or is there anything else i could do to fix it?
Old Apr 27, 2010 | 10:54 AM
Ron W.'s Avatar
Ron W.
And the code is = ????
Old Apr 27, 2010 | 04:34 PM
chriscox1980
running rough
i guess everything hadnt reset yet from changing out the imrc when i coded it before. the codes are PO171, PO316, PO303, PO174. a starting point would be helpful
kvjn777
Apr 2, 2013 06:42 AM
Willie928
Sep 21, 2012 04:21 PM
rynehiter
2004 - 2008 F150
Mar 18, 2011 01:29 AM
mvtofino
May 5, 2003 05:18 AM
Gatewood1
May 2, 2000 10:18 AM
