Offroad & 4x4
Anybody running ARB's?
Old Apr 26, 2010 | 08:48 PM
lannondiesel's Avatar
lannondiesel
Is anyone else running ARB lockers? I have them front and rear on my 78 F-250. They are about 8 years old and I think the blue air lines are starting to get fragile. I see a stress crack in one section going to my front axle and its not leaking yet but it is the beging of wheelin' season and i would rather take care of it now then after it blows. I was thinking about removing the blue lines and running a hard line like some brake line or something that is a little more durable. Has anyone done anything like this? Or should I just replace the blue plastic hose every 10 years? Also just curious what other people think of the ARB's? I am thinking about getting rid of them and going back to conventional lockers.
Old Apr 27, 2010 | 09:14 AM
mark a.'s Avatar
mark a.
I will only ever use Powr-loc's in a vehicle I own.
Old Apr 27, 2010 | 09:18 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I don't have ARB's currently, but know lots of people that do.
Those blue air lines will get brittle over time (depending on your weather conditions), just replace it with conventional air line - any shop that sells pneumatics will sell it, can pick it up really cheaply, and its an easy job.
Old Apr 27, 2010 | 09:21 AM
lannondiesel
Sounds good. I will look into that. Should be easy enough!
Old May 7, 2010 | 12:46 AM
wyoming4x4's Avatar
wyoming4x4
Arb's rule!
I live in ice country and arb is way better than a conventional posi on ice. I see your picture in snow so I'm guessing ice is part of your world. We got about 8" of snow today/last night in northern wyoming. Not sure of your situation but selectable lockers are nice compared to not having a option at all. Hose is a quick fix and easy to repair. Catch you later, lost in wyoming and lovin it! I run a powr lok rear but have to replace clutches every couple of yrs due to wear. they work OK but if you lift a tire the power goes to the tire in the air if clutches are worn. Selctable locker will win in this situation if tire is in the air.
Old May 7, 2010 | 06:54 AM
purple98tj's Avatar
purple98tj
I used copper lines right up to where I had to change to flex line. I only have to change out about three feet of line if it cracks.
MK2Pierce
Dec 10, 2014 06:38 PM
Tim Young
1966 - 1977 Early Broncos
Feb 8, 2014 12:52 PM
robertbruce
Jul 27, 2013 12:15 AM
SuperDutyScaler
Dec 28, 2011 02:52 PM
oldmansimek
Offroad & 4x4
13
Feb 16, 2011 10:14 PM
