Air condition problems
Old Apr 26, 2010 | 06:06 PM
Motor3440's Avatar
Motor3440
Hey Gents,
Has anyone had any problems with there AC? The truck is back in a 4th time. During the hottest parts of the day it will just blow cool not cold. when you accelerate up the AC blows cold, but when the RPM drops down to 1500 it goes back to cool. When you put your hand up to the vents you can feel it switch back. At night and early morning it blows cold.
So far the dealer has replaced the compressor shaft seals where they found a leak, oriface tube that was clogged with sediment, fan clutch assembly, and recharged with freon
2006 F350 PSD, CC, SRW. It also has the electric AC controls. Any help would be greatly appreciated.
Old Apr 26, 2010 | 07:04 PM
DSMMH's Avatar
DSMMH
Originally Posted by Motor3440
Hey Gents,
Are your condenser (in front of the IC) fins OK and not bent over?
Is your serpentine belt old? If I remember correcty the belt does not make much contact with the AC compressor pulley. A worn strecthed slick belt could be the problem.
This is a long shot but with regard to the electronic controls make sure the vacuum pump is operating.
DSMMH
Old Apr 26, 2010 | 07:18 PM
Motor3440's Avatar
Motor3440
Not to sure about the condenser fins are bent, as for the serpentine belt the truck has only 34,000 so im not sure if that would be the cause. The vacume leak could be possible cause. I will be going by the dealership tomm to check the progress. They wanted to keep the truck overnight to replicate the condition. when I dropped it off it was raining and cool out.
Old Apr 26, 2010 | 07:34 PM
janton01's Avatar
janton01
2 weeks ago had to have the ac sys rebuilt on my 04 F250. The manifold line from the compressor, the one that is wrapped in insulation had rusted very badly. The rust had gotten into the system and trashed the compressor. Replaced the compressor, reciever dryer manifold and orfice tube. $800 later all works as it should. The rust was under the insulation so not readily evident.
Old Apr 27, 2010 | 04:13 AM
Motor3440's Avatar
Motor3440
I will have the teck look at the insulated line today and look into the rust in the line
Old Apr 27, 2010 | 05:44 AM
gearloose1's Avatar
gearloose1
Generally speaking, in salt use areas, insulation of the lines on the outside exposed to road salt is a bad idea.
Unless the insulation completely seals the line.
Old Apr 27, 2010 | 04:33 PM
Motor3440's Avatar
Motor3440
Were in the So. Florida area so the salt is not to bad here.
They're going to keep the truck for another day, so far everything checks out. They think it may be a flapper thats staying open alowing outside air to mix with cold air causing it to blow cool. Thay also want to check up in the fan housing to see if some foreign Matter got stuck up in there. and last but not least the compressor motor.
So we shall see what we come up with.
Dcook136
6.4L Power Stroke Diesel
Jan 14, 2015 03:14 PM
J33P4L1FE
May 20, 2014 08:59 PM
cobenson
2004 - 2008 F150
Jan 28, 2014 03:51 PM
Bones327
Oct 31, 2013 05:09 PM
Big Norm
1997 - 2003 F150
Sep 16, 2013 09:53 PM
