4wd problem
Old Apr 26, 2010 | 04:16 PM
*95f150*'s Avatar
*95f150*
4wd problem
i recently bought a 95 ford f150 xlt wit push button 4wd and now im havin issues wit the 4wd its showin its in 4H and it wont go out of it or even go into 4L, maybe somebody could help me out, thanks....could the speed sensor cause this problem cause my speedo dont work either and my overdrive button on the shifter is constantly flashing to Thanks for any help that i could get from ya'll
Old Apr 26, 2010 | 07:23 PM
KevinGnWV's Avatar
KevinGnWV
The village idiot.
I used to have a 95 F150 with the pushbutton and I had to put the trans in neutral to shift it into low range.
Also, have you tried backing up to release the 4wd?
Old Apr 27, 2010 | 08:55 AM
Ohio Ford Farm's Avatar
Ohio Ford Farm
I would start with the speed sensor. Your OD light flashing is telling you that your trans has a problem. The speed sensor let the computer know how fast your going and that's how it figures out when to shift. This will cause it store a code and make the OD light blink. ( Is it shifting funny ? ) It also works your speed O. The transfer might not be trying to shift if its not seeing the drive shafts turning? But that's a guess.
Old Apr 27, 2010 | 04:03 PM
*95f150*'s Avatar
*95f150*
thanks for the help, ive tried doin the neutral trick thing and reverse also, it seems to shift alright not sure havent drove it a whole lot to no plates and insurance on it right now, im goin to replace the speed sensor in the next few weeks
