Intake Question
Old Apr 26, 2010 | 12:17 PM
elbob's Avatar
elbob
Intake Question
im getting ready to install a new Edlebrock Performer 390 intake and a 1407 carb on my 68 F150, 360. currently there is a 5/8 heater hose running through a plate located under the carb... what's that?
also, any pointers would be appreciated...
Old Apr 26, 2010 | 01:28 PM
elbob's Avatar
elbob
i just read where it is a water heater spacer block... Elelbrock says i don't need it... what is it's purpose?
Old Apr 26, 2010 | 02:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The original carburetor spacer plate has a tube on it that the heater hose connects to.
This is designed to warm the mixture that passes thru the spacer plate.
Old Apr 26, 2010 | 03:02 PM
elbob's Avatar
elbob
thanks...
so is it going to cause a problem not having it?
Old Apr 26, 2010 | 09:50 PM
Ford_Six's Avatar
Ford_Six
Not in your area. In colder climates, it's nice to have since it help fight carb ice. If you run an open air cleaner in the winter, you'll have carb ice problems. You need to run an air cleaner with a hot air diverter to prevent the problem fully.
Old Apr 27, 2010 | 12:44 PM
elbob's Avatar
elbob
thanks, i appreciate the info
Samsn4
Nov 19, 2012 08:19 AM
65fordguy
Nov 6, 2007 01:58 PM
donnachie
Nov 9, 2002 05:03 PM
flatliner
Sep 3, 2002 01:50 AM
David
19
Jan 29, 2000 08:01 PM
