fog light ????
Old Apr 26, 2010 | 11:13 AM
RSUPERDUTY's Avatar
RSUPERDUTY
Question fog light ????
Any of u guys electrical gurus?
I'm installing two more of the stock fog lights in between the two in the factory location. ? is how many amps would these babys use. I'm wanting to use the upfitter switches in my 05 f250. Thanks for any info in advance
Old Apr 26, 2010 | 12:29 PM
riggz's Avatar
riggz
Amps = Watts / Volts
So if they are 55w bulbs, you would have 55w / 12v = 4.6a * 2 = 9.2 amps per pair
Old Apr 26, 2010 | 12:31 PM
Cowboy65's Avatar
Cowboy65
The OEM halogen bulb should be rated for 45 watts (3.75A) each .
Old Apr 26, 2010 | 12:39 PM
RSUPERDUTY's Avatar
RSUPERDUTY
EXCELLENT guys. This forum is great.
THANK YOU
Old Apr 26, 2010 | 12:42 PM
riggz's Avatar
riggz
I thought the Fogs were H3 55w bulbs?
Old Apr 26, 2010 | 01:08 PM
RSUPERDUTY's Avatar
RSUPERDUTY
They are 42watt bulbs.
Old Apr 28, 2010 | 03:07 PM
Raptor 6.2L's Avatar
Raptor 6.2L
hooking up fog lights to upfitters
please if someone knows where the other end of the upfitter harness is located and color code. I have 4 fogs i am putting on and i dont want to go ahunting 2010 f150 raptor 6.2 The light are pias with the yellow/blue bulb
Old Apr 28, 2010 | 03:11 PM
riggz's Avatar
riggz
Ah, the bulb is a 9145. I got them confused with the bulbs in my old truck's fog lights. Should be a 45 watt. Not heard of a 42 watt?
Old Apr 28, 2010 | 03:15 PM
riggz's Avatar
riggz
You might want to try asking in the correct forum. https://www.ford-trucks.com/forums/forum243/
Old Apr 28, 2010 | 04:45 PM
RSUPERDUTY's Avatar
RSUPERDUTY
I found the info in the tech folder under upfitter wireing location.
The sylvainia bulb saie 12v42 watt on it....
