302 fuel injection
Old Apr 25, 2010 | 11:37 PM
seafire's Avatar
seafire
302 fuel injection
I have a 70 F100 2wd long box that has 302, auto, and PS. I am thinking about up dating the engine to 302 fuel injection. I found a 89 F150 for parts that has engine and all wires. Can this be done relative easy?
Thanks for all the help.
Old Apr 25, 2010 | 11:56 PM
Beef Stew's Avatar
Beef Stew
I did a 5.0 efi swap and I'd say it's relatively easy IF you're good with wiring. Personally I'd pass on the speed density F150 motor and try to find a MAF Mustang motor. Much easier to work with.
Search for posts by me and you'll find info on my swap.
Old Apr 26, 2010 | 04:02 PM
seafire's Avatar
seafire
MAF Mustang
I have never heard of MAF Mustang.
Old Apr 26, 2010 | 04:13 PM
Beef Stew's Avatar
Beef Stew
Well that tells me how much you know about EFI. Maybe you're better off not doing the swap.
Old Apr 26, 2010 | 04:34 PM
seafire's Avatar
seafire
engine swap
A person can always learn.
Old Apr 26, 2010 | 05:19 PM
Beef Stew's Avatar
Beef Stew
LOL you're right man... even the most knowledgable people started off not knowing anything! Sorry for being harsh.
MAF means mass air flow. Most the Mustang motors came with MAF sensor. Basically the MAF sensor measures the actual mass of air entering the engine. The computer applies a certain air mass-to-fuel mass ratio and viola, you have a running engine. As air flow increases fueling increases with it. Very simple and effective system.
Speed density means the computer is looking at the engine speed and air density. Engine speed is obviously rpm and air density is computed by looking at manifold pressure (MAP sensor) and air temp. Based on changes in manifold pressure the computer can infer airflow and apply a certain amount of fuel. Also very simple but slightly less adaptive than MAF engine management.
Basically you can make small air flow changes to a MAF motor and the ECU will correct the fueling to match the change in air flow. Speed density motors are tuned for one configuration only. If something significantly changes the air flow into the motor then the computer must be retuned to correctly meter fuel flow.
So anyways, I think the genearl concensous is that MAF motors from a Mustang are easier to work with.
ItsAFord55
Oct 4, 2011 03:06 PM
sanfortandson
Nov 18, 2008 09:39 AM
Country705
May 12, 2006 11:43 AM
seaway
Jan 3, 2004 01:59 AM
canadianfordman
Oct 1, 2001 05:00 AM
