Door sticker decode Help
Old Apr 25, 2010 | 11:27 PM
blueovalbigblock's Avatar
blueovalbigblock
Question Door sticker decode Help
Hey guys i need some help figuring out what gear ratio is in my 88 bronco rear end. The sticker on the door has an axle code of 19. does this tell the ratio? i Know its a 8.8 just need to know the ratio
thanks for any help!
Old Apr 25, 2010 | 11:31 PM
skucera's Avatar
skucera
My manual shows that axel code 19 has a weight rating of 3800 lbs. and a 3.55 axle ratio.
Scott
Old Apr 26, 2010 | 12:01 AM
phoneman91's Avatar
phoneman91
Scott
And the differential is open.
Old Apr 26, 2010 | 11:04 PM
skucera's Avatar
skucera
Now that is a nugget my manual doesn't have. Perhaps you can answer a question about my axle. I have an F250 with axle code 65, which my table shows is a 4.10 ratio with a weight rating of 8250 lbs. Is it open or limited slip?
Thanks,
Scott
Old Apr 26, 2010 | 11:29 PM
Cowboy34's Avatar
Cowboy34
how about on my 1991 Ford F150 XLT Lariat 4x4,it shows a H9 as the axle code,any help!!
Old Apr 26, 2010 | 11:35 PM
skucera's Avatar
skucera
I've still got the page open. Axle H9 is 3.55 axle ratio with 3800 lb. weight rating. My table doesn't have anything about limited slip vs. open, though.
Scott
Old Apr 26, 2010 | 11:42 PM
892504x4's Avatar
892504x4
Thanks,
Scott
56 is an open the rest you are correct on according to my book
Old Apr 26, 2010 | 11:56 PM
skucera's Avatar
skucera
I take it "56" is just "65" transposed. If so, I thank you for confirming what I thought. Now I know that I really have to be careful about getting stuck in our slippery Willamette Valley clay soil.
Scott
Old Jan 28, 2011 | 11:31 AM
stupidcosmoline's Avatar
stupidcosmoline
so 91 f150 door tag says 18N under axle.....so would that be 3.08? whats the N mean?
Thermoss
Modular V10 (6.8l)
Apr 28, 2017 06:53 AM
gila_dog
Mar 16, 2016 04:11 PM
petruccifan88
18
Jan 10, 2016 07:00 PM
bigdaddyII
2004 - 2008 F150
Jan 23, 2012 05:47 PM
greatdays2gether
Sep 18, 2010 02:03 PM
