too much negative camber?
Old May 4, 2010 | 09:12 PM
tvans63's Avatar
tvans63
Originally Posted by bigunit54
Yeah, I noticed the holes where the lower control arm bolts in are slotted. Do you guys ever have any problem with them slipping after they are adjusted? Also, since you have done ball joints, how much labor should I expect to be involved? It looked like the axle would have to be unbolted to get it out, but when the weight is off the wheel is there enough clearance to get it out without dropping that axle?
once the lower control arms are tight they shouldnt move, if you hit a bump or a nasty pot hole there is a possibility they will move
Charlie Tee
1983 - 2012 Ranger & B-Series
Nov 12, 2016 09:04 AM
93dakman
2009 - 2014 F150
Nov 1, 2016 07:49 AM
Z3T3C
19
Aug 13, 2014 03:48 PM
banjopicker66
24
Apr 8, 2013 11:49 AM
boosteddsm
16
Aug 9, 2011 07:34 AM
