did my timing today......yeah!!!!!!!!!!
Old May 21, 2010 | 10:41 AM
ymeski56's Avatar
ymeski56
Der Postmeister
Originally Posted by traxx808
your so right ymeski56 i am having problems keeping my foot out of it!!! i bet if i did the mileage would be a lot better......haha..........
Anybody else want to try it, here's the link.
FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs
Can't have any active Error codes, no Vac leaks, Compression does not have to be great, just relatively balanced. Stick w/ 87 octane. 13.5 BTDC is mentioned & easily attainable, but 16 BTDC is the sweet spot.
Combustion Chamber deposits are a big reason you may Ping before reaching 16 BTDC.
How to Seafoam an Eighth Gen F150 (1987-1991) - Ford F150 Forum - Community of Ford Truck Fans
Don't use Platinum plugs/ Use Stock Nic plated Copper Cores/ Mototcraft or Aulolites. Increase gap till miss, then reduce gap .002.
Then increase Base timing 2 degrees at a time until Ping is reached under load. then reduce advance 2 degrees. Spout plug out for timing check & adjustment, then replace. On an otherwise stock engine, more than 16 BTDC is not worth it.
This is an Ignition upgrade w/ gap stretch & Base Timing bump that will pay for itself with a Performance & MPG increase very quickly. Enjoy!
