General Automotive Discussion
99 Taurus Issues
Old Apr 24, 2010 | 01:55 PM
Icefan71's Avatar
Icefan71
99 Taurus Issues
Hi everyone. I have 2 issues with my 99 Taurus SE DOHC. First, the brake pressure seems a little low. It passed inspection like this but sometimes you have to give it 2 pumps to build up the pressure when you are slowing down. I replace both front to back brake lines and bled the system. They were rotted, but the problem is still there. There are no other leaks anywhere. All connections are tight. I replace the cap on the fluid reservoir. And it doesn't lose any fluid. I was gonna replace all the rest of the brake lines, but I dont want to do all that work for nothing and they dont look bad anyway. Also, the pads, rotors, drums, shoes are all new and there are no leaks in the calipers or wheel cylinders.
My second problem is with the a/c. The previous owner said they replaced the compressor themselves. I charged the system and the clutch keeps cycling on and off every 5 seconds. I kept a gauge on the low pressure port while I watched the clutch engage @ 44psi and turn off as pressure dropped to 15psi and the air is not blowing cold. Any input would be appreciated. Thanks.
Old Apr 24, 2010 | 05:34 PM
Old_Crow's Avatar
Old_Crow
Did you draw a vacuum on the a/c? Rapid cycling of the clutch usually indicates under charging of the system.
Old Apr 24, 2010 | 07:21 PM
Icefan71's Avatar
Icefan71
I just found out from a friend that I should have kept charging the a/c until the clutch stayed running. I didn't realize that once it starts, the pressure is supposed to drop as it is filling the system. So I guess it is undercharged. i try it again tomorrow.
Old Apr 25, 2010 | 01:45 PM
Icefan71's Avatar
Icefan71
A/C seems to be working now. I just need to wait and see if it doesn't leak. I'm still looking into the issue with the brakes.
Old Apr 25, 2010 | 01:56 PM
Lazy K's Avatar
Lazy K
Are you confident that the rear shoes are properly adjusted up? If so then, from your description, I would think there is still air in the system.
Old Apr 27, 2010 | 02:13 PM
Icefan71's Avatar
Icefan71
I'll check the shoes, Lazy K. And I'll have to drag the wife outside to help me bleed them again.
Old Apr 27, 2010 | 02:40 PM
senix's Avatar
senix
I am thinking that if you re-bleed the system and it is still spongy then maybe your master cylinder is letting something by.
Just a random thought.
Old Apr 27, 2010 | 02:43 PM
khadma's Avatar
khadma
Carpenter Local 745
We have a 1999 also and these cars are awesome, easy to work on and affordable to own.
I agree there still may be air in the lines, but did you replace all the fluid?
Keep us posted.
Old Apr 27, 2010 | 03:03 PM
Lazy K's Avatar
Lazy K
Bleed right rear then left rear then RABS module (if fitted) then right front then left front.
Old Apr 27, 2010 | 07:17 PM
Icefan71's Avatar
Icefan71
Lazy K, I checked the shoes and they needed to be adjusted out slightly. I went for a quick spin and problem solved. Thanks to everyone for their help.
fordparts76
1983 - 2012 Ranger & B-Series
Feb 25, 2011 10:40 PM
Old_Paint
Jul 30, 2006 02:16 AM
Motorhead-42
May 23, 2006 06:10 PM
gibsonj
Oct 11, 2005 08:28 AM
1987tc
Dec 7, 2002 11:45 PM
