Front end suspension ???'s
Old Apr 25, 2010 | 07:51 AM
tepid1's Avatar
tepid1
Sounds like we have the same problem. Suspension sounds loose when you hit a bump, right?
Mine also just started squealing while turning. Oh, the fun. haha
Old Apr 25, 2010 | 08:10 AM
SUPERDUTY OUTLAW's Avatar
SUPERDUTY OUTLAW
I think i'm going to bite the bullet and get everything ordered. Does anybody have the tool for the axle seal they are talking about that I could borrow? Some kind of special one.
Old Apr 25, 2010 | 08:14 AM
Waltdog's Avatar
Waltdog
of American machinists
You can make the tool for 10 bucks at home depot. To bad your not closer you could have mine I wont ever need it again
Old Apr 25, 2010 | 08:16 AM
Waltdog's Avatar
Waltdog
Pictures of the tool in this thread
https://www.ford-trucks.com/forums/3...ll-joints.html
Old Jun 13, 2010 | 01:09 PM
Waynenap's Avatar
Waynenap
Originally Posted by Waltdog
You might also consider replacing the steering box at 200K
Red-Head Steering Gears, Seattle WA - Red-Head Steering Gears Home
New steering box 350-375
Ball joint kit 300-350
Tie rod ends and drag link 200-250
Sway bar kit 50
alignment 50-60
U joints 100
misc 40
If you did every bit of labor you would be at about 1200 for just parts
Walt,
Is that price you have for a new steering box, for a Red-Head? There's not much information on their website, I guess you'd have to call them.
Old Jun 14, 2010 | 07:41 PM
kbeefy's Avatar
kbeefy
I wouldn't mess with the steering box until you service everything else. Jack up the front and give it a good shake-down. Prybar method works good for checking balljoints and bearings. Check steering and panhard by having someone turn the wheel while you look at/feel linkages for play.
Clunking over bumps is probably swaybar bushings or shock bushings. You might be able to check by pushing down on the front of the truck, but those springs are pretty stiff.
At 200k, I'd suspect ball-joints and wheel bearings.
Grinding in 4x is probably front ujoints, maybe driveshaft joints.
Slop in the steering is likely panhard bushings and/or tie rod ends. It's not necessary to change the linkages, just the ends.
Hubs probably just need a cleaning, the vacuum diaphragm is probably shot, after two sets I gave up and plugged the vacuum and just use them manually, they work fine.
Old Jun 14, 2010 | 08:03 PM
lucaslaw's Avatar
lucaslaw
Heck the Moog tie rods are 100 or so each from Rock Auto, stealership usually too expensive.
LL
fatforty
Aug 18, 2014 05:38 AM
bigamer44
Feb 13, 2012 06:32 PM
plbolton
33
May 27, 2007 09:27 AM
thinksnow
Oct 7, 2003 06:15 AM
