dually to single wheel
Old Apr 23, 2010 | 10:58 PM
mammothstroke's Avatar
mammothstroke
bought a 93 350 4x4 dually from auction.good shape for industrial plant electrican truck.new 7.3,rear diff,front diff,and service body never had shelfs installed in.for $3 G's.selling service body changing it to a pickup.also thinking of changing it to single wheel.read some on the do's and don'ts.anyone ever done this.would it be worth all the work.
Old Apr 24, 2010 | 02:59 AM
LCAM-01XA's Avatar
LCAM-01XA
That truck is likely a "stripped chassis" truck with the narrower frame - the dually axle is narrower than the dually pickup-bed axle too, and actually if you simply pull the dual rear wheels and install singles the truck will become just as wide as a regular SRW pickup-bed truck. For the front it kinda depends on what style wheel hubs you got, as some DRW 4x4 trucks have essentially a SRW frnot axle with just hub extenders added to make up for the deep-ish dually wheel - remove these extenders and bolt your single wheels in their place. There are however one-piece front hubs too, they are dually-specific and there's no adapter you can take off - if you got one of these axles then you gotta swap the DRW hubs out for some SRW hubs for the same axle...
Old Apr 24, 2010 | 08:48 AM
Diesel_Brad's Avatar
Diesel_Brad
The cab-n-chassis rear axle(67") face of drum to face of drum. A SRW pick up axle(64") face of drum to face of drum. And your spring perches are 44.5" wide on a SRW axle (center pin to center pin), and the cab-n-chassis is 40.5"
LCAM is correct for the front axle though, you can just unbolt the dual adadapters
Old Apr 24, 2010 | 09:47 AM
redlightning93's Avatar
redlightning93
Also, the cab to rear axle diminsion on a cab and chassis will be different from a pickup so the pickup bed will have a gap between the bed and back of the cab. This is assuming that the chassis is a 60" c/a and the pickup c/a will be 57".
Old Apr 24, 2010 | 10:55 AM
mammothstroke
dually to single
thanks guy's.mine's is 57" to c/a .it is 133 wb .and front hubs have the adapters for dually.i'll check these other measurments.keep the reply's comin.
Old Apr 24, 2010 | 07:13 PM
LCAM-01XA's Avatar
LCAM-01XA
Wait, ain't the pickup-body dually axle 4" wider than the SRW axle, which would put it at 68" from drum face to drum face? I was under the impression that the cab-chassis axle is identical in drum face to drum face width to the SRW axle, but accommodates for the dually wheels (being more offset than the singles) by moving the backing plates and the leaf springs 2" inboard on each side (confirmed by your spring perch width numbers)...
Old Apr 25, 2010 | 06:43 AM
Diesel_Brad
A pick up dually axle is at least 70" if not more
Old Apr 25, 2010 | 04:14 PM
LCAM-01XA's Avatar
LCAM-01XA
Ok, just to clarify, by "drum face to drum face" do you mean the surfaces where the wheels mount to?
Old Apr 25, 2010 | 07:58 PM
mammothstroke
re drum face
Yea thats what they are refuring to.i'm trying to find some wheels to try on my truck.
Old Apr 26, 2010 | 08:22 AM
Diesel_Brad
Yup! Sure do
Old Apr 26, 2010 | 09:29 AM
82F100SWB's Avatar
82F100SWB
Hmm, 133" wheelbase and bolt on hub adapters, almost sounds like a pickup dually with the bed swapped out and not a C&C to me.
Old Apr 26, 2010 | 11:19 AM
Brown Falcon's Avatar
Brown Falcon
If it's a regular F350 (not cab and chassis) then it's a straight bolt in swap from the DRW axle to SRW axle as long as it's a 10.25 axle from a '97 and older F-series.
I did this on my truck last year. Bought it as a dually, swapped in a SRW axle in less than a day. Then swapped the front hub/rotor assembly.
Before and after pics in my garage gallery.
Old Apr 26, 2010 | 05:45 PM
mammothstroke
dually to single
my truck is deff a c&c it is around 34"across the frame rails.around 41"centerbolt to centerbolt on rear springs.trying to find some wheels to see how bad it would look.prob have to swap the rear out and move the spring pads.hate to though rear is new,front is new,7.3 is also new.hopfuly i can keep project moving to a finished picup.
Old Apr 26, 2010 | 06:05 PM
LCAM-01XA's Avatar
LCAM-01XA
Do try with a pair of junkyard wheels first tho, it may just work - if Brad is right on the dimensions the wheels will sit only about an inch firther out than they would with a factory SRW axle, which is really not a big deal.
Old Apr 26, 2010 | 07:41 PM
Brown Falcon
If it's a C&C the wheels will sit and inch further IN than a SRW axle. If it was a regular pickup dually it would sit and inch further OUT...
The C&C dually axle was the narrowest of the 3
Pappawheely
Jan 29, 2016 11:53 AM
PGC
Apr 19, 2015 09:18 PM
twwtruck
Sep 15, 2012 10:20 PM
gareth12
Dec 1, 2011 10:41 PM
300FOREVER
Mar 19, 2010 06:19 PM
