EEK#@&%
Old Apr 25, 2010 | 10:59 PM
Fuelhog 5212's Avatar
Fuelhog 5212
Truck accelerates without throttle input
Say guys, after putting in a new lift pump and getting air out of things I noticed that twice now while accelerating through about 20 to 30 mph that the truck is moving faster than it should as I am not pressing down on the pedal. Its basically accelerating on its own for a short burst and then seems to settle down. Maybe still some air in the lines somewhere?
Old Apr 26, 2010 | 02:14 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
It could be Air surge, however it sounds like the governor is sticking, do this.
Go get your favorite Diesel Additive Cleaner/Lubricator.
  1. Warm up the truck.
  2. Shut it off.
  3. Pull the filter.
  4. Pour it out. (In an environmentally safe manor)
  5. Fill it up with your choice of Diesel cleaner/lubricator. (Diesel Kleen or whatever)
  6. Re-Install filter.
  7. Double or even Triple the mix of cleaner/lubricator in the tank.
  8. Start the truck.
  9. Let it run for 1 minute or so.
  10. Shut it off.
  11. Let it set for awhile ... Pretty much longer the better, to a point.
  12. Then take it for a ride.
The point is to get the cleaner/lubricant into the Injection Pump and let it set for awhile.
It should clear up within a tank fuel.
-Enjoy
fh : )_~
Old Apr 26, 2010 | 06:23 AM
Fuelhog 5212
Ok, I will get on that asap, I think you are correct on the governor sticking as it is running smoothly other than the issue I described. I'm getting quite an education on these motors, thanks to you and some other guys on this site, thanks again. As they say, any day you learn something is a good one..
nlemerise
15
Apr 22, 2012 03:59 PM
RoadJunkie
6.4L Power Stroke Diesel
116
Apr 17, 2011 11:51 AM
gearhead351
Feb 9, 2009 09:31 PM
Sleepsafe
Dec 21, 2008 06:50 AM
irishammer
16
Aug 6, 2008 09:21 PM
