Air Pump removal
Old Apr 23, 2010 | 06:18 PM
leardvr's Avatar
leardvr
Air Pump removal
1992 E350 7.5L E4OD
Thought I'd put this out there.
My airpump seized up (finally) and when it did I needed to replace the tensioner also.
Anyway, all the searching I did talked about removing the whole pump.
I just removed the pulley (3 10mm bolts if I remember) and put on a 48" belt and used the alternator to adjust the tension (2 belt system). ALT sits in the exact same place it did before.
So there you go, remove the pulley and 48" belt. Your result may very.
JimG1098
2004 - 2008 F150
Oct 1, 2015 10:57 AM
SammySwiss
1978 - 1996 Big Bronco
Jun 22, 2015 06:39 AM
1996F150XL
May 27, 2014 06:16 PM
sammie0126
Apr 21, 2014 10:14 PM
88_F0RD
13
Apr 4, 2014 04:55 AM
