Turbo whine normal?
Old Apr 23, 2010 | 09:20 AM
spatengal's Avatar
spatengal
Turbo whine normal?
Good Morning
I am back to pick all the fantastic brains on this site. You guys are the biggest help there is available.
I have a 2001 7.3 dually 4X4 crew cab Centurian Package. It has the DP Tuner, 4 stage. It was geared verrrry low so instead of changing both front and rear end I installed a Gear Vendor and it is great. Also put on a 4" turbo back exhaust system. I have pillar gauges, 3 gauges. Have a modified air filter.
OK now to my question when I ask the truck to work I hear a whine at about 15+ psi on the turbo boost. I am not a hot rodder but do tow rv's in the mountains in the Pacific Northwest. I can hear the turbo in normal situations winding down but am worried about the whine when I ask it to work. It is a WAG that it is the turbo but I could not think of anything else. It has NO smoke or blow by of any type. Has almost 90K miles on the odo.
I do not particularly like this specific truck=I am a Ford person but just not this truck but since trucks are not worth much with the price of diesel so high I am stuck with it so had better keep it running or I am walking.
Should I be worrying about the turbo?
Thanks again for all the brain power here. You guys are much appreciated
Thanks
Pam
Old Apr 23, 2010 | 09:26 AM
Kwikkordead's Avatar
Kwikkordead
Good morning Pam.
The sound that you are describing, does it sound similar to a police or fire truck siren?
If so, then you have a chipped intake or exhaust wheel, most likely the intake.
If it's more of a whistling noise, much higher pitched than a siren, that is normal.
Old Apr 23, 2010 | 09:52 AM
spatengal's Avatar
spatengal
Thanks
Thanks Kikkordead. You have answered my many questions in the past. I will take the truck out today and see if I can hear the difference
Pam
Old Apr 23, 2010 | 10:31 AM
Izzy351's Avatar
Izzy351
What Dan said. You can also pull the intake off the turbo to do a visual inspection for chips. Should be nice, sharp edges like this:
That is mine without the intake housing on it, but that's what the wheel looks like. That is the stock wheel -- Wicked Wheel (if you have one) will look different with 10 vanes instead of 9, alternating one large, one small...
Izzy351's Avatar
Izzy351
Dinosaur-Bones
Oct 13, 2010 10:43 AM
kpjr
19
May 3, 2010 08:01 PM
Kallie
Dec 27, 2007 11:45 AM
Linusgump
Feb 17, 2005 10:33 PM
pdipizzo
Feb 8, 2003 12:16 PM
