Complete Newbie
Old Apr 23, 2010 | 03:36 AM
F350-6's Avatar
F350-6
Originally Posted by Pansen
Oh, and how can I find reputable Ford mechanics?
You'd have to start by telling us what city and state you're in, but if you're this excited about trucks, hang around here and we'll have you doing this all yourself in no time.
And there's no rush about all the other stuff to make it better for towing. You can do a little at a time, and you can do it all yourself. Go find your trailer and enjoy. When you're ready to start improving things, we'll help you do it in the right order and keep you from wasting your money on unnecessary or inferior stuff.
Old Apr 23, 2010 | 06:58 AM
Izzy351's Avatar
Izzy351
Where are you getting the 5th wheel? Most RV dealers will put the hitch in and wire the connector for you.
Old Apr 23, 2010 | 07:42 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
I have nothing to add, yet.
Old Apr 23, 2010 | 07:54 AM
joeyd61's Avatar
joeyd61
BUMP....welcome
Old Apr 23, 2010 | 07:57 AM
64F260's Avatar
64F260
Just wanted to add that if you guys are totally new to diesels, they do sound much different than a gas engine, they can be a bit noisy it is probably just the normal engine sound. Some people have "insulated" thier cabs with special material to soundproof them more. In a way, a diesel sounds like a gas engine that is "knocking" a bit. Another thing that may help is adding 2 stroke oil to the fuel at half ounce to one ounce per gallon of fuel, since the new ULSD fuel doesnt lubricate the injectors like the old fuel did. You can search for more info on this.
Old Apr 23, 2010 | 08:23 AM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
Pan,
Welcome to FTE. I have one suggestion, check the air filter some people have fallen into the hipe about K&N air filters. The K&N filter is a bad thing for our trucks, they cause problems with the turbo and will damage the engine. If your truck has one you need to remove it soon. The stock Ford filter will do the job for your needs
Old Apr 23, 2010 | 09:24 AM
dsquared's Avatar
dsquared
Welcome to FTE!!! This is a GREAT resource for all sorts of info about your truck!! A lot of knowledgable people that are quick to help, and you don't feel like an idiot on here (although sometimes I may act the part...)
My guess is your name is not Tia, but that is "Thanks In Advance"......
Ask away, spend some time, you'll learn lots!!
Old Apr 23, 2010 | 01:15 PM
Pansen's Avatar
Pansen
Yeah, my name is not TIA (thanks in advance). It's Pan, but I don't mind Tia.
I still can't believe we have this big ol' truck. I forgot to mention it's a dually.
I'm in the Bay Area, east bay near Concord, CA. But we're moving up to Redding soon.
Old Apr 23, 2010 | 01:27 PM
frdf250's Avatar
frdf250
Hi there! I just bought a 2001 Ford F350 7.3 liter diesel engine crew cab (long bed?). We got it to pull around a 5th wheel we will be living in part-time. I know nothing about diesel vehicles, and barely know a thing about vehicles in general, except I love driving a big truck. My husband, not so much.
The truck drives great, but it's very loud and it has a noise that reminds me of rockers or pistons hitting metal or something. Is that normal for a diesel truck? It also sometimes smells really badly in the cab like chemicals. One day, I opened the cab and it smelled like someone had spilled nail polish remover. Hmmn...
Is there anything we can do to the truck to make pulling around a 5th wheel easier or more enjoyable? We have had the truck for less than a week, and we haven't purchased our 5th wheel yet.
TIA!
ETA: I posted this in the wrong forum at first. Ooops. Also, by loud, I mean a LOUD knocking sound.
welcome to fte, just to make ya feel alittle better i came to this site not knowing how to change my oil on any car or truck about a year ago. i certinally dont know everything now but hang around here and youll be sure to learn plenty.
as for finding a rep mechanic...you are now your own mechanic. we will help you out as much as we can.
Old Apr 23, 2010 | 02:52 PM
clem1226's Avatar
clem1226
If your moving up to Redding get a 5th wheel with the best insulation and the largest AC unit you can find. I grew up in Redding an vacation there most summers and it gets HOTTT !! Arizona hot!! If I don't start my AC at 6 am and keep it running max my 5th wheel is un inhabitable until after the sun go's down.
Good luck and welcome to FTE!!
as a side note, be careful with any modifications you perform. California just instituted smog checks for diesel vehicles and a few members on this board are having a heck of a time getting their to pass.
Old Apr 23, 2010 | 03:53 PM
wolfrace's Avatar
wolfrace
You like apples?
Hey Pansen, give the engine a good bath in simple green elbow grease and a hose make sure to get the hood heat covering and a good amount of simple green in the vents in front of winshield bottom, this fixed up my diesel Boo-Boo (blown gasket on the feaul bowl................) oh ya cover alt., air filter, PS pump.
You can get alot of advice on quietening the motor.......... airdog, hutch mod, in tank harpoon mod, and FRx.....................the search button, will help find a lot of info, I am still learning alot from these guys.........
Ps. my wifey picked our/her truck..............
Old Apr 23, 2010 | 07:10 PM
F350-6's Avatar
F350-6
If it gets that hot, then you should also consider the cold AC mod. I don't have a link handy, but it involves a bypass valve from either a ranger or excursion, a couple of hose clamps and splicing into a vacuum tube and heater hose.
Old Apr 23, 2010 | 08:11 PM
  #28
Pansen's Avatar
Pansen
Good advice about the smog. I bought this truck from a dealer who had to get it smogged, so thankfully I know, at this point, it can pass. Adding mods, well... hmmmn.
Yeah, insulation will be a must! We'll be living in it for awhile, and I'm thinking we might have to build a carport for it to stay out of the heat while on our property.
And I'm not exactly new to auto repair. My friend taught me a lot about gas engines, and had me changing oil, hoses, distributor caps, batteries, etc... I've never done anything extensive though, and never with a diesel vehicle. In fact, most of my past vehicles were stick shift to avoid tranny repairs (although there was a clutch and all, but those are cheaper). It's been years since I've done any of those things on my own, and I have the typical "girl syndrome" of not wanting grease under my nails.
I'll have to get over it.
Thanks for the advice. Keep it coming!
Old Apr 23, 2010 | 08:32 PM
  #29
Izzy351's Avatar
Izzy351
Grease is eh. Diesel soot under your nails is downright sexy!! LMAO!!
Old Apr 23, 2010 | 09:56 PM
  #30
JonathanN's Avatar
JonathanN
Yeah, ditto that... the 7.3L literally has a roar to it. It has a little cackle to it as you're cruising and as you get into it, it'll cackle even louder until it downshifts and then it begins to roar. It's also quite a bit louder too if it has an aftermarket exhaust... hang a round a bit and you'll learn. I've learned a TON from these guys already!
