Sponsored by: Auxito
Straight
Old Apr 22, 2010 | 04:28 PM
49 Ford F-1's Avatar
49 Ford F-1
Straight
Does any on know if there is a Straight Axle swap kit for a 1997 f150? I would like one that has like at lest a 6" lift with it, but would reather have one with a 8 to 10" lift though.
Old Apr 22, 2010 | 08:34 PM
steve(ill)'s Avatar
steve(ill)
4 x 4 ? what are you going to do for springs/ shocks?
Old Apr 22, 2010 | 09:14 PM
49 Ford F-1
Not sure I was hopeing there was a kit. I already have it on a RCD 5.5 in lift. Yes it is a 4x4.
Old Apr 23, 2010 | 11:03 AM
49 Ford F-1
So there is no one that knows of any kit?
Old Apr 23, 2010 | 11:07 AM
allis bob's Avatar
allis bob
|| Farmboy Fabrications - The Suspension Specialists ||
Old Apr 23, 2010 | 11:56 AM
49 Ford F-1
thanks man there kits looks great I think I'm going with a 9 in lift with the 3 in body lift.
Old Apr 23, 2010 | 01:11 PM
TheTinian's Avatar
TheTinian
X2 on the farmboy kit.
Iv'e got 14.5 suspension and 3 inch body.
Old Apr 23, 2010 | 01:12 PM
allis bob's Avatar
allis bob
Post some picks of the project would be awesome to see
Old Apr 23, 2010 | 01:14 PM
TheTinian's Avatar
TheTinian
https://www.ford-trucks.com/forums/9...ere-it-is.html
Old Apr 23, 2010 | 01:18 PM
TheTinian's Avatar
TheTinian
I had a build thread goin, but it got a little ugly and it got closed.
I'll post a bunch of pics on the whole build soon.
Old Apr 23, 2010 | 08:45 PM
49 Ford F-1
Looks good man. I don't think i would go up that high though. The only time mine goes off road is when I'm hunting. How hard was it to install, and what motor you running? You have anything done to it?
Old Apr 25, 2010 | 12:24 PM
TheTinian's Avatar
TheTinian
Well i started the build oct. of last year. and just dropped it off yesteday to do the gears and front shaft to be 100%.
I'm running a 5.4 with throttle body, tb spacer, cold air intake and headers
5.13's, 1410 yokes, superior chromo'd 35 splines with nitro joints.
Its expensive and alot of work, but its worth it IMO.
Old Apr 25, 2010 | 03:53 PM
49 Ford F-1
Ok kool. I put a 99 lightning motor in my truck with a 10lb pully on the supercharger, poted and polished heads, a custom cut cam, and full custom exhoust. I know I would have the power to pull any size tire that I wanted to. Also I have 4.88 gears in it now.
Old Apr 25, 2010 | 06:20 PM
TheTinian's Avatar
TheTinian
damn!
How was the swap? I looked into it, but i kept reading it wasn't worth it and should prob just buy a supercharger kit.
Old Apr 25, 2010 | 06:54 PM
49 Ford F-1
well I started with a 97 4.6. The 4.6 in that year only had 220hp to flywheel. I'm guessing the truck has around 430 rwhp and something like 475 to 500 rwtq. So it would of been the some kind of foulish for me to just go with a normal 5.4 when I could swap out for a Lightning 5.4. It is kind of a headack, but it is well worth it. I had to fab brackets and things. I really need to have it dyno tuned, but I can't find a place that will do it bc of the 13.5 in wide tires on it. To tell you the truth I picked up like 2 to 3 mpg by doing the swap. The truck just has the power to pull it's self now, and with the 4.6 it didn't. O yea it also has the power to pull all imports, most Chevys and Dodges around.
