360 mod questoin
Old Apr 22, 2010 | 12:15 PM
76F250rustbucket's Avatar
76F250rustbucket
Question 360 mod questoin
you'll have to pardon my fordtarded ness i know alot about chevy engines but not squat about ford im getting a 1976 F-250 with a 360 and four on the floor the body is rusted out but the frame and engine are good. anyways i noticed on the sticker it says engine class 360/390 so does that mean if i put a 390 crank and rods in it it would be a 390 and can it be stroked more than that is it the same bock as the 427 and others? i dont know ford motor history but hopefully u guys do cause if im going to restore this bad boy i want it to be mean might even go with fiberglass for the cab and front clip but only if i win the lotto LOL
Old Apr 22, 2010 | 05:47 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Swapping a 390 crank and rods would get you a 390 as they share the same block.
A Ford 427 block is completely different (in a sense) different oiling, cross-bolts and most aren't drilled for hydraulic lifters. 68-72 427 Service blocks are dilled for hydraulic lifters however.
Josh
Old Apr 23, 2010 | 10:04 AM
76F250rustbucket
thats what figured o well a 390 4speed will still be sweet
