Front axle shaft
Old Apr 22, 2010 | 10:56 AM
mudbug04's Avatar
mudbug04
Front axle shaft
Hey guys I got a question...
Right now my front axle shaft (drivers side) is a little loose and when im driving it rattles quite a bit . With the wheel, tire, everything on i can grab the locking hub and wiggle the hub a little also. What all holds the axle in place and still? The wheel bearing, differential bearing, locking hub, is there anything else?
i changed the wheel assembly about 6 months ago, changed all the seals & thrust washers but that was it... did i miss something?
