sbf water pumps
Old Apr 21, 2010 | 05:56 PM
1bad67sbf's Avatar
1bad67sbf
sbf water pumps
im looking at getting a march pulley kit and have to use a reverse rotation water pump. other than the water neck on the driver side the bolt pattern is all the same for the timing covers or not?
Old Apr 21, 2010 | 07:12 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
All that I've ever seen are.
Old Apr 21, 2010 | 07:17 PM
1bad67sbf's Avatar
1bad67sbf
thanks i wanted to be shur i dont have to get a timing cover
Old Apr 22, 2010 | 04:54 AM
EPNCSU2006's Avatar
EPNCSU2006
It's been a while since I had the timing cover off of my truck, but I thought that the coolant ports were blended slightly in the direction of the water flow.
Old Apr 22, 2010 | 05:16 PM
1bad67sbf's Avatar
1bad67sbf
i think the biggest change was the timing pointer (some like mine are part of the cover and some others bolted on) but i dont know alot of small stuff on the later 302 (after around 1985)
Old Apr 23, 2010 | 04:54 AM
EPNCSU2006's Avatar
EPNCSU2006
I checked yesterday on the 351 I have in the garage, and the water passages are specific to pump rotation direction. I don't think you could get a standard rotation pump to seal on the reverse rotation timing cover and vice versa.
Old Apr 23, 2010 | 04:13 PM
1bad67sbf's Avatar
1bad67sbf
ok thanks ive found a pulley kit for a standard rotation. its cheaper to go that way and not have to buy the pump, radiator for a lower driver side outlet, hose, ect thanks for everyones advice
lizardman1
Jul 19, 2021 10:51 PM
dlr281
Dec 9, 2015 04:49 PM
CharlieLed
Oct 17, 2015 12:24 AM
ben73058
31
May 23, 2015 08:32 PM
