It finally happened
Old Apr 21, 2010 | 04:17 PM
mohle's Avatar
mohle
It finally happened
233800 KM and it started coughing white smoke yesterday morning. The beast is over at the dealer now. Diagnosis EGR cooler, oil cooler, water pump and front cover.
Apparently the Ford warranty rep is coming to view it at the dealership. Repair costs apparently exceed what they consider normal.
Old Apr 21, 2010 | 11:31 PM
billbot's Avatar
billbot
all the problems seem to go hand in hand, you'd think ford wouldn't think twice about doing the repairs. hopefully you get your truck back soon
Old Apr 22, 2010 | 05:55 AM
backspace's Avatar
backspace
had a local mechanic say that was probably the problem with mine although I only have 80K miles. I'm starting to hear my clutch fan come on more and more when towing. Also smell some coolant every now and then. Did you have that going on?
Old Apr 22, 2010 | 07:55 AM
ehgeeray's Avatar
ehgeeray
You must have a serious warranty to still be covered with 233800KM!
Old Apr 22, 2010 | 08:47 AM
Bruce F250's Avatar
Bruce F250
My truck in the shop now. 90k miles. EGR cooler, oil cooler, head gaskets, ARP studs, brakes, and ball joints $6,800.
Old Apr 22, 2010 | 08:57 AM
rickatic's Avatar
rickatic
Backspace,
You have the classic symptoms of egr cooler/oil cooler syndrome. You need to get the egr cooler replaced or deleted and the oil cooler replaced asap, like now. Driving it increases the chance of oil cooler rupture and a mess you never want to see, let alone clean up. BTDT. Install a coolant filter before you drive with your new coolers.
Regards
Last edited by rickatic; Apr 22, 2010 at 08:58 AM. Reason: poor proofreader, he is fired
Old Apr 22, 2010 | 09:20 AM
69cj's Avatar
69cj
Originally Posted by rickatic
Backspace,
Regards
Double ditto rickatic.
Old Apr 22, 2010 | 01:31 PM
mohle's Avatar
mohle
Backspace,
Regards
I've got the Ford Diesel Enginecare Plus. Here in Canada it's good for 7 years or 300,000 KM. After this, it will have been well worth the $2500 or so that I paid. Wish I could have gotten it on the tranny as well. I know the symptoms, that why it's at the dealer. I already have my coolant filter built, but not installed yet. I talked to the mechanic here and they said that it would void my warranty. So until 300,000 I won't be putting it in or changing anything from stock. As stated they are replacing the oil cooler, egr cooler, front cover and water pump. After that they will do more tests to check the head gaskets.
I also discussed the latest flash with the mechanic and he doesn't buy any of the talk regarding setting a code when the temp difference between oil and coolant is 15 degrees. Mine got the flash last December and never set a code. I was driving down the freeway, when I had to slow down my fan came on. The next day when I was already planning on taking it to the dealer, I could see white smoke and smell coolant. He has yet to see one with the new flash that has. Maybe Cheezit can shed some light on that?
Old Apr 22, 2010 | 01:38 PM
mohle's Avatar
mohle
I hadn't really towed a lot over the last few months, but my fan had come on a few times since I got the latest flash - with relatively light loads. Figured it was part of the new programming.
What gets me is that one can do everything according to the book, synthetic fluids, filters, flushes and all that and still have this dreaded issue.
Old Apr 22, 2010 | 08:22 PM
rickatic's Avatar
rickatic
mohle,
I would talk to the service manager at your dealership regarding the coolant filter and your warranty status. if you wait until your warranty mileages out, you will be putting 66,200 km or over 40000 miles on your new oil cooler. It will also act as your coolant filter for that distance. I would not want to take the chance that this will happen again at 301000 km.
Regards
Old Apr 22, 2010 | 09:03 PM
mohle's Avatar
mohle
mohle,
Regards
No worries there. By then I won't have the truck anymore or I'll take it in for the developing rear main seal which should also be under warranty. I would have them do a good once over. The mechanic working on mine was once an employee of mine and we still keep in touch. I'm sure that he will be doing a very good job on it. The way I'm racking up the KM, I'll hit 300,000 by this fall.
Old Apr 23, 2010 | 06:55 AM
ehgeeray's Avatar
ehgeeray
I just had my oil cooler rebuilt and flushed the cooling system. I installed a coolant filter at that time. I drove 200Miles and the first filter is clogged already! LOL
How much crap can be in there? hopefully my oil cooler is not clogged again!
Old Apr 23, 2010 | 07:03 AM
rickatic's Avatar
rickatic
Exactly the reason why I would not drive 10 feet with a new oil cooler without a coolant filter.
Old Apr 23, 2010 | 12:31 PM
ehgeeray's Avatar
ehgeeray
It would be best to install the coolant filter 1000 miles before you rebuild the oil cooler.... It's not always possible though.
Old Apr 23, 2010 | 07:52 PM
rickatic's Avatar
rickatic
ehgee...
I agree with you 100% on that one. I will be able to know ahead of time now if my cooler is clogging. My oil cooler failed catastrophically so no chance to filter early.
