hay ALL
Old Apr 21, 2010 | 12:33 PM
myutesux's Avatar
myutesux
hay ALL
I Just went to get a rego check the so called mechanic said every thing fine just a few little things eg parking light on passenger side DID work but pass owner put the wrong headlight in it needed the stanley globe that has parking light option so you can see the dam thing had the wrong headlight in it I just bought this truck in nov 2009 so I didn't know what was in it away the exhaust tail was loose so i fix that cool he also said the fuel tank was unsafe so I looked at it yesterday an it seemed to ok to me so I just thought I tighten up the blot on the petrol tank bracket on the passenger side and it snapped off JUST GREAT now it hanging off so I just ordered a U NUT from MAC'S Antique Auto Part online just wanna KNOW if this is the right bit because the original looks a different ****** http-equiv="content-type" content="text/html; charset=utf-8">379831-S EACH 0.95 U-NUT 5/16-18 THREADED CLIP BLACK OXIDE FINISH USED MANY PLACES THROUGHOUT THE BODY 1 1948-1979
Old Apr 21, 2010 | 01:03 PM
compman25's Avatar
compman25
How about a period or two? That sentence makes no sense/
Old Apr 21, 2010 | 02:17 PM
berry1234's Avatar
berry1234
Wow............................................... ....................
Old Apr 21, 2010 | 02:43 PM
Furyus1's Avatar
Furyus1
A headlight with a parking light option? I'm not sure what that is. Is it the same truck that's in your album? You have the 2 headlights, 2 turn-signal/parking lights above the headlights, and a marker light on each fender.
As for the fuel tank. Where on the truck is the tank located?
Old Apr 21, 2010 | 09:07 PM
myutesux's Avatar
myutesux
this is a headlight with parkinglight separate
I have a different set up my parking lights are in separate unit..... It"s a sealed beam but has hole with clear plastic over the hole..... for park light cheers an you an you guys never told me if that's the right LITTLE HELP ******
Old Apr 21, 2010 | 09:12 PM
myutesux's Avatar
myutesux
7 inch Sealed beam headlight 75/90W
Old Apr 21, 2010 | 09:19 PM
myutesux's Avatar
myutesux
HAVE A LOOK
THIS IS A HEAD LIGHT WITH PARK LIGHT OPTION check out my Album BORIS 16 pictures
Old Apr 21, 2010 | 09:26 PM
myutesux's Avatar
myutesux
i am soory about grammer
PERIODS fullstops question marks
Old Apr 21, 2010 | 09:49 PM
berry1234's Avatar
berry1234
Dude, your posts are very annoying to read. If you expect anyone to help, take your time and make an attempt at a complete thought and sentence. The way it is written now, it reads like the ramblings of a meth addict.
Old Apr 21, 2010 | 11:21 PM
Furyus1's Avatar
Furyus1
OK, I had to do a bit of digging, but I found this:
Alfa Romeo Spider Headlight With Parking Light New : eBay Motors (item 200456447976 end time Apr-30-10 09:13:51 PDT)
What vehicle do you have?
If it is a '73-'79 Ford truck, I'm not sure any of those came with these style of headlights - unless yours were custom-fit by someone...
These trucks had standard dual-beam (high/low) lamps.
If yours is a custom install and is wired differently, then I can't say whether or not what you have is "right".
Old Apr 22, 2010 | 11:44 AM
myutesux's Avatar
myutesux
sorry about the grammer.
I am not on drugs.. the site messenger is cutting some of my words up an not making sense "sorry" about that. The light I have is a Stanley. I have a picture in my Albums of my truck. An the parking light is on the bottom of the fuse system that plugs into the sealed beam which has high&low built in. The park light is a different globe all together sorry about the confusion, I have found one on ebay so not to worry thanks
Old Apr 23, 2010 | 12:53 AM
f100racing's Avatar
f100racing
Not shore about the tank without pics.
My truck has had a H4 coversion so i don't have that problem,BUT, all Aussie utes had a 7" sealed beam headlight usually with 65/50 high/low globe. They also had a small hole under the plug for a seperate parker light. On all Aussie vehicles the turn signal is just a turn signal, not a parker.
The 7" sealed beam light is the same on all 70's Aussie Falcon/Fairlanes so should be easy to find a replacement.
Old Apr 23, 2010 | 08:00 AM
myutesux's Avatar
myutesux
THANKS MATE
I have the light on ebay its all good
rockher_man
Ford Truck Parts for Sale
Sep 12, 2012 10:29 PM
SunBum
Aug 8, 2010 07:52 PM
myutesux
May 6, 2010 07:33 PM
myutesux
Mar 7, 2010 11:26 PM
rockher_man
17
Aug 7, 2009 10:11 PM
