windows, ABS and overhead console inop
Old Apr 21, 2010 | 11:25 AM
HH60FE's Avatar
HH60FE
Buddies 2000 350 has the windows, ABS, overhead console and ESOF inop. Is the secondary computer (cant remember the acronym, not the PCM) the one that controls these things and is that a dealer only with a flash install? Thanks much
Old Apr 21, 2010 | 12:12 PM
HH60FE's Avatar
HH60FE
Think I found it after an extensive search. ECM. Thats what his mech. told him. I say an old post that AutoXone had them and they were programed. Does this check? If so, is it just a remove and replace?
Old Apr 21, 2010 | 12:18 PM
tdpower's Avatar
tdpower
I think the ECM is another word for PCM. I was thinking maybe the GEM module but not sure if it controls all of those. Has he got it scanned?
Old Apr 21, 2010 | 01:02 PM
tdpower's Avatar
tdpower
Here are the GEM functions
The GEM/CTM controls the following functions:
Wipers/washers
Warning chimes
Illuminated entry and courtesy lamps
One touch-down (OTD) driver power window
Remote keyless entry
Accessory delay
Electronic shift 4-wheel drive
Old Apr 21, 2010 | 02:22 PM
HH60FE's Avatar
HH60FE
Grant, I might be thinking GEM. I did a search and found a write-up in Feb 09 with reference to an ECM. I don't think his symptoms point to a PCM, as the truck runs just fine, he's having issues with the ESOF, windows (all) overhead console and ABS.
I called AZ and they knew what I was refering to when I said ECM. He needed the part # off the old one as there were 10 different numbers for that year truck. He also said it needed flashing. Maybe I'm doinked up in my thinking. Anyone else come accross this?
Old Apr 21, 2010 | 09:02 PM
HH60FE's Avatar
HH60FE
bump for me
