Cowl vent survey
Old Jan 29, 2003 | 09:03 AM
ferguson777's Avatar
ferguson777
Question Cowl vent survey
Guys,
Kai's thread on cowl vents has me curious about something -
How many guys (that have functional cowl vents) have trouble with water leaks through the vent and how many have had no trouble at all?
I'd like to have my vent functional (as I won't have air conditioning) but not if it's going to be a continual problem with leakage.
Old Jan 29, 2003 | 09:21 AM
fatfenders's Avatar
fatfenders
Cowl vent survey
RMF
I can't give you any real world ice and snow data. I have pressure washed my truck many times with leaking noted. I have new rubber seal and adjusted for good fit. Tension spring adjusted snug so it stays shut. You can easily lok under thedash and see if you are getting good seal compression.
Old Jan 29, 2003 | 09:24 AM
bobj49f2's Avatar
bobj49f2
Cowl vent survey
I have had my '49 on the road for over five years without any leakage from the cowl vent. The vent really helps on the hot days, I wouldn't go without it.
Old Jan 29, 2003 | 09:30 AM
ferguson777
Cowl vent survey
'fenders (my jiggly buddy),
Other than when you're spray washing it, do you get any leaks?
Old Jan 29, 2003 | 09:33 AM
Midnite Cruiser's Avatar
Midnite Cruiser
Cowl vent survey
Its a true mark of the breed, having the vent openable.
I have gone thru restoring the seal, levers and brackets after a HACK put a dash hole and radio in that area.
Amazing how much better the wiper motor mounts on the stock dash bracket too.
No major seal problems, but I would worry more if there was carpeting instead of the rubber floor mat
Point is, there are side benefits to gettin' back the Vent!
Old Jan 29, 2003 | 10:50 AM
fatfenders's Avatar
fatfenders
Cowl vent survey
OOPS
Another 'fenders typo. It does NOT leak when I pressure wash. I see no reason why it should leak when closed with a good seal.
I also agree with cruiser. The vent is part of the charm of an F100. I hate irreversible changes to the body. I get queasy when when door handles and body seams start disappearing. My truck was hacked pretty bad when I got it or I would have less mods than I do. To each his own I guess. There are plenty of hacked trucks out there so the guys that want to radically modify have plenty of project material. The wild mods go out of style eventually though.
Old Jan 29, 2003 | 11:58 AM
41Clay's Avatar
41Clay
Cowl vent survey
My '52 never leaked, before or after I replaced the hard-cracked seal. I think the only way that it could is if some leaves or something blows in there and keeps it from closing completly and the rain pours like mad.
Clayton
Old Jan 29, 2003 | 02:19 PM
cabby daddy's Avatar
cabby daddy
Cowl vent survey
installed new seal, and it is functional... no leaks at this time...
but it hasn't been out of the shop, in the rain in the last 1 1/2 years either.
Old Jan 29, 2003 | 02:49 PM
ferguson777
Cowl vent survey
Cabby Daddy,
You slay me. If it ever does actually get out into the elements, let me know if it leaks, eh.
In response to my Jiggly Buddy's sermon - Yah, I prefer primarily stock lines with minimal changes to body panels. I feel it would be a crime to seal it up and cover it over. Plus, without real air conditioning - I suspect there will be a lot of "air conditioning" to be had from having said vent open. I do plan to have carpetting so I really don't want something prone to leakage though.....
To respond to a recent question of yours - "634-5789" (Get it?, think about it)
So far, all responses to my question seem to indicate no great predisposition to leaking though, so that's encouraging. Keep the results coming.
Thanks,
Old Jan 29, 2003 | 05:30 PM
mtflat's Avatar
mtflat
Cowl vent survey
Mine is a replacement from a parts truck as the one in the '48 was gone. With nothing to go by, I installed like I thot it should be in there.
My vent does leak, but to be honest I haven't tried too hard to adjust it properly since it was on the road - only excuse is laziness and other priorities. One of these days..........
On the other hand, I'd never close it up permanently. On those hot summer days that natural air does wonders for my disposition - and it moves a LOT of air!
Old Jan 29, 2003 | 06:14 PM
fatfenders's Avatar
fatfenders
Cowl vent survey
Cabby Daddy,
In response to my Jiggly Buddy's sermon - Yah, I prefer primarily stock lines with minimal changes to body panels. .....................................
RMF
I confess, I have no idea what the numbers mean nor your meaning of a "Jiggly Buddy" Drop me a PM if it's not fit for primetime.
Thanks
Old Jan 29, 2003 | 07:03 PM
ferguson777
Cowl vent survey
'fenders,
634-5789 is the name of a song featured on either BluesBrothrs1 or 2. Performed by the artist who's name escapes at the moment and Johnny Lang. It's probably the most catchy song ever written. It's one of those that when it comes on, you crank it way up and everyone starts singing at the top of their lungs. The performance in BB1 or 2 is a real hoot as well.
You'd have to see the performance in the movie to understand the joke.
It's one of my five favourite songs of all time.....
Old Jan 30, 2003 | 11:29 PM
dgb2002's Avatar
dgb2002
Cowl vent survey
ferguson777
keep the vent my vent was welded up and i hate not haveing it.
grant
49 f1
Old Feb 2, 2003 | 08:08 PM
286merc's Avatar
286merc
Cowl vent survey
It took a lot of PB Blaster to get my vent to work but after that its been no problem, the rubber floor mat stays dry at all times. Looks like some kind of rope and rubber seal, kinda ratty but it works; probably original like most of the truck.
1954 F350
Old Feb 3, 2003 | 12:44 PM
Karm's Avatar
Karm
Cowl vent survey
I have a '52 F-1 and love the cowl vent, put a new seal on it and tightened it properly and it has never leaked.
But, the old owner decided to tear off the door seals when he did the poor job repainting it... so every time I wash or am in rain, the doors leak But, the way I see it, if I am going to have it professioanlly repainted, why bother putting in new seals if I will need to rip them out in a few years anyway
