Sponsored by: Real Truck
Fuel Tanks
Old Apr 20, 2010 | 10:44 PM
Heavy Duty f250's Avatar
Heavy Duty f250
Fuel Tanks
Does anyone know of an aftermarket fuel tank company? I would like a larger fuel tank in the stock location for an F250 2005 with the 5.4 motor. All the places I have tried including Titan fuel tanks they only make them for diesel tanks
Old Apr 21, 2010 | 02:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
You're going to run into a lot of diesel tanks and very few gasoline tanks. It is very hard to get government approval for the larger gasoline tanks, since they are considered part of the emissions equipment.
Diesel engines don't have the evaporative canisters (and associated tubing and monitoring crud) to control fuel fumes.
Old Apr 21, 2010 | 08:02 AM
baylessbell's Avatar
baylessbell
Try transfer flow tanks. I just got a 47 gallon in my 09 f250 5.4. It's the only place I could find that made one for a gas truck.
Old Apr 21, 2010 | 08:37 AM
Thomas D.'s Avatar
Thomas D.
Transferflow.com Without a doubt one of the best aftermarket fuel tank companies to deal with. Stock location gasoline tanks are limited due to above stated reasons but they have some great in bed and combo tool box options. They have some great install deals if you happen to be around the Chico, Ca. area.
Old Apr 21, 2010 | 06:57 PM
Heavy Duty f250
I'm in Florida. I was hoping not to tie up bed space. Can you modify a diesel tank to work? I'm going to check out Transfer Tanks. Thanks
Old Apr 21, 2010 | 08:44 PM
baylessbell
The transfer flow tank that I bought is a replacement for the factory tank. It mounts in the original location so we still have full use of the bed to haul our 4 wheeler.
Old Apr 21, 2010 | 09:58 PM
Heavy Duty f250
Do you have any information on this fuel tank like who you ordered it from? Thanks.
Old Apr 21, 2010 | 10:47 PM
KRDiesel's Avatar
KRDiesel
I have the transfer flow 47 for my diesel. Nice tank, heavy steel. I wonder if the "diesel" tank would work also.
Old Apr 22, 2010 | 01:42 AM
redford's Avatar
redford
Transfer flow does make larger replacement tanks for gas engined trucks.
Ford pickup replacement tanks
Old Apr 22, 2010 | 08:18 AM
baylessbell
Check the transfer flow website for a dealer or talk with a local truck accessory place to see if they can get it. I'm in texas so the place I bought mine is gonna be a little far for you to drive. Transfer flow will ship it to you if you want to do it yourself.
Old Apr 22, 2010 | 09:28 AM
superdutysquirrel's Avatar
superdutysquirrel
diesel tanks are less regulated on placement than gas because of there explosive values. gas being a lot more explosive, the tanks have to be located where they cant be punctured in wreck. that is a lot of the reason in bed tanks have the warning labels on them that they are for diesel only.
Old Apr 22, 2010 | 10:39 AM
brian42's Avatar
brian42
Veteran: Navy
Old Apr 22, 2010 | 04:30 PM
scraprat's Avatar
scraprat
Top Answer: 5
Looks like a nice tank except the OP was asking about "gas" not diesel.
Old Apr 23, 2010 | 11:04 AM
brian42's Avatar
brian42
Veteran: Navy
My bad. I thought they made both.
Old Apr 23, 2010 | 11:30 AM
Heavy Duty f250
Found Transfer Tanks. When I get extra money I'm gettin one.
