Rancho 9000xl
Old Apr 20, 2010 | 05:42 PM
BIGRED 7.3L's Avatar
BIGRED 7.3L
Rancho 9000xl
I just installed some adjustable 9000XL on my truck. Does any one that has these have a recommendation on the best way to set these up as far as front to rear settings? Stiffer in the front softer in the rear? Let me know if you have a successful set up...as I am not overly impressed with them at this point.
Old Apr 20, 2010 | 07:51 PM
59JEEPSTANG's Avatar
59JEEPSTANG
These are great shocks. I use them on my Jeep and love them, one day may have a set on Truck. I would start same front and rear, maybe about a 6 or 7 (if I remember correctly goes to 9 or 10) and drive a while and then adjust the fronts up or down and drive for a while again. Then repeat, if ride gets worse go the other direction.
Good luck,
Paul
Old May 3, 2010 | 10:24 PM
gotwakex45's Avatar
gotwakex45
Old May 3, 2010 | 11:08 PM
429PI IN 75 f-100's Avatar
429PI IN 75 f-100
How much were the the shocks for your truck i knew they were 100.00 for my 75 f-100 with a four inch lift. Trucks getting to the point were she needs some new shocks, if you are going to chase coyotes around having the shocks turned up to nine is the best so you have less body roll while turning real sharp
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Macs1964F100
Feb 7, 2016 09:31 PM
HiZ
Nov 4, 2015 09:56 AM
johnsonjf
Nov 1, 2015 10:10 AM
Powelligator
Oct 5, 2013 12:43 PM
Andy91st
May 18, 2010 11:57 AM
