Data Plate Decode...Please.
Old Apr 20, 2010 | 05:28 PM
03-6L-X's Avatar
03-6L-X
F25YR790707
Wheel base: 129
Color: JM
Model: F250
Body: E81
Trans: A
Axel: B4
MaxGVW: 07500
Cert Net HP: 172 4000
D.S.O.: 746900
Also what size rims and tires came with this originally? Both front and rea have eight (8) lugs.
Thank you for your help.
Old Apr 20, 2010 | 05:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 03-6L-X
F25YR790707 // 129 / JM / F250 / E81 / A / B4 / 07500 / 172 / 4000 / 746900
Also what size rims and tires came with this originally? Both front and rear have eight (8) lugs.
Must be decode day, this is my 3rd this afternoon.
F25 = F250 2WD
Y = 352 2V.
R = San Jose Assembly Plant.
790707 = 1966, assembled in December 1965.
129" Wheelbase.
JM: J = Rangoon Red / M = Wimbledon White.
F250 2WD / 7,500 lbs. GVWR
E81: E = Red Crush Vinyl & Red Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
B4 = Dana 60 / 4.10-1 / LIMITED SLIP / 5,200 lb. Rear Axle Capacity.
7500 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
746900:
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
6900 = Domestic Special Order number. Your truck was ordered special by the original purchaser, not "bought off the lot."
16" x 5.5" 8 lug 6.50" bolt pattern wheels were standard equipment on F250's. They could be split rims, they may not be.
16" x 6" / 17" x 5.5" / 17.5" x 5.25" / 19.5" x 5.25" wheels were optional.
Look around the valve stem area for an ID number, post what you find.
Old Apr 20, 2010 | 06:00 PM
03-6L-X's Avatar
03-6L-X
I do not have the original rims they were replaced with some white spoke wheels.
Need to get new tires. Last set were Uniroyal Laredo 9.5R16.5 LT M+S Load D.
If possible would like to get back to Original.
Old Apr 21, 2010 | 12:13 AM
mikeryan77's Avatar
mikeryan77
Data Plate Decode
Hi Number Dummy,
Looking for help decoding VIN F61CR844827, 1 1966 F-600 dump truck
481, color M, 71, axle G30, it has a V8, 4 speed trans and a 2 speed rear.
Thanks,
Mikeryan77
Old Apr 21, 2010 | 04:02 AM
camperspecial65's Avatar
camperspecial65
mikeryan, the VIN decodes easily enough... but the rest of the info doesnt fully make sense given the way the codes are stamped and labeled on the warranty plates.
The VIN is as follows:
F61= F600 series(theres 6 different models in 1966) F610-F615
C= 330 2bbl carb, gas engine
R= San Jose, Ca assy.
844827= April 1966 assy date(april run was 844,000 to 857,999)
The other info you posted I can make sense of is color...M= Wimboldon white exterior paint
481= 4: Medium beige crush vinyl and medium beige wicker pattern vinyl.
81=81A= a standard model truck
the rest is where it gets confusing...first off...one medium and heavy trucks there is 2 axle codes...one for the front and one for the rear axle...
On the warranty plate below the warranty number..aka VIN is the 2nd line of codes...from left to right:
W.B.
Color
Model
Body
Trans
Axle
The next and bottom line has codes for the following from left to right:
Max GVW Lbs
Cert Net H.P.
RPM
DSO
Fill in the blanks so it can be completely decoded.
- cs65
Old Apr 21, 2010 | 04:25 AM
NumberDummy
Originally Posted by mikeryan77
F61CR844827 // 71 // axle G3O
Welcome to FTE
C = 330 2V Medium Duty FT engine.
71 is prolly: Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
AXLE G3O:
G3 = Eaton Model 16802 2 Speed Rear Axle / 6.50-1/9.04-1 / 17,000 lb. Rear Axle Capacity.
O = Ford Rockwell-Timken Front Axle / 9,000 lb. Front Axle Capacity.
Old Apr 21, 2010 | 04:31 AM
camperspecial65
Bill, I found the front axle codes...BUT I only found the O or 0 being for 1964 model trucks...p.78, Gen. Info. section
I did forget the M/D on the engine...LOL..and the 71 for LA DSO...That scenario hadnt crossed my mind...I was going L to R on the tag in my mind as the codes were posted compared to how warranty plates are laid out.
- I did find the G3 though a cpl min. ago...btw..is the O a letter or the number zero ???
- cs65
Old Apr 21, 2010 | 04:41 AM
NumberDummy
If G3O is the correct AXLE code (it's not G30), what else could the O refer to?
Parts catalogs are not infallible.
The OP said his truck has a 2 speed rear axle, what G3 decodes to.
We'll just have to wait and see what transpires.
I wish ppl would list the info in the correct sequence as found on the Warranty Plate (as you pointed out).
When the codes are topsy-turvy, catty wampus and some are omitted (as in post #4), it's a royal PITA to decode.
Old Apr 21, 2010 | 02:57 PM
mikeryan77's Avatar
mikeryan77
1966 F 600 Dump
Number Dummy and Camper Special 65. My apologies, I sent the data plate info from memory.
The VIN iS F61CR844827 and the Data Plate reads as follows from left to right;
WB 481, TRANS A, AXLE G30
GVW 24,000, 164 HP@3,800 RPM, DSO 71
MF 615 81 A G30 is the last line across the bottom.
I thank you both very much for the information.
Check out the latest Super Duty videos on the Ford site. We recently shot "Fuel ", "Torque", "Trailer Sway" and "Off Road" with Mike Rowe.
Best, MikeRyan77
Old Apr 21, 2010 | 04:32 PM
mintf100's Avatar
mintf100
NUMBER DUMMY............................. I would like for you to decode my vin please!!!!!!!!
it is F10JE591491.........I am trying to get this truck ready to sell!!!
Old Apr 21, 2010 | 05:51 PM
NumberDummy
The info as you've listed it...is still out of the sequence.
F61CR844827 (decoded in posts # 5 & 6)
WB 481, TRANS A, AXLE G3O
GVW 24,000, 164 HP @ 3,800 RPM, DSO 71 This is the third line.
W.B. (omitted) MF F615 481 A G3O is the second line.
481 is the BODY code. I dunno of any truck that has a 481" wheelbase!
This is the correct sequence as listed on the Warranty Plate.
W.B.
COLOR MF: M = Wimbledon White / F = Sahara Beige.
MODEL F615 = F600 2WD / 24,000 lbs. GVWR
BODY 481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl // 81 = 81A Standard Cab.
TRANS A = New Process 435 4 Speed Manual Transmission.
AXLE G3O: G3 = Eaton Model 16802 2 Speed Rear Axle / 6.50/904-1 / 17,000 lb. Rear Axle Capacity // O = Ford Rockwell-Timken Front Axle / 9,000 lb. Front Axle Capacity.
GVW 24,000 = 24,000 lbs. Gross Vehicle Weight Rating.
HP 164 = 164 net HP
RPM 3800 / Combined: 164 net HP @ 3,800 RPM
DSO 71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Apr 21, 2010 | 06:15 PM
NumberDummy
Originally Posted by mintf100
F10JE591491.
F10 = F100 2WD
J = 240 1V I-6
E = Mahwah NJ Assembly Plant
591491 = 1965, assembled September 1964.
Old Apr 21, 2010 | 06:45 PM
camperspecial65
My goodness...it just goes to show a picture is worth 1000 words...give or take...Im glad it got sorted out in short order though...
Did you have any Dirty Jobs for Mike :-) I love him on it as well as Deadliest Catch which he narrates
- cs65
Old Apr 22, 2010 | 01:38 PM
mikeryan77's Avatar
mikeryan77
Finally got it right on the data plate
F61CR844827
WB 144, COLOR M, MODEL 615, BODY 481, TRANS A, AXLE G3D
MAX GVW 24,000, CERT. NET 164 @ 3800 RPM, DSO 71
F61CR844827
M F615 81 A G3D
Old Apr 22, 2010 | 03:36 PM
NumberDummy
F61CR844827
WB 144, COLOR M, MODEL F615, BODY 481, TRANS A, AXLE G3D
The above is correct, but...I erased the second VIN and that other jazz, which is not listed like that on the Warranty Plate.
F61 = F600 2WD (gas).
C = 330 2V Medium Duty.
R = San Jose CA Assembly Plant.
844827 = 1966, assembled in April 1966.
144" Wheelbase.
F615 = F600 2WD (gas) / 24,000 lbs. GWVR
481: Medium Beige Crush Vinyl & Medium Wicker Pattern Vinyl / 81 = 81A Standard Cab.
G3D: G3 = Eaton Model 16802 2 Speed Rear Axle / 6.50/9.04-1 / 17,000 lb. Rear Axle Capacity // D = Ford Rockwell-Timken Front Axle / 7,000 lb. Front Axle Capacity.
