1957-1960 4X4 Spicer 24 Mount and Crossmember
Old 03-29-2010, 09:45 AM
montego69's Avatar
montego69
montego69 is offline
Guys,
Any of you have some pictures of the transfer case crossmember used to mount the Spicer 24 transfer case in the '57 to '60 trucks? I'm turning my 4X2 into a 4X4 so I'm curious what the factory original looks like.
The picture in my 57-63 ford truck master parts catalog is hard to interpret how it actually looks in real life.
Thanks much!
Nick
Old 03-29-2010, 04:24 PM
montego69's Avatar
montego69
Guys,
Maybe I can clarify my question a bit. Was the 57-60 4X4 transfer case crossmember actually two crossmembers that carried the Spicer unit or was it 1 like the 61 and newer trucks?
Thanks,
Nick
Old 03-31-2010, 09:18 AM
montego69's Avatar
montego69
crossmember
Guys, please, does anyone know if the 57-60 transfer case crossmember actually two separate cross pieces or just one like what's in the 61-65's?
Nick
Old 03-31-2010, 11:07 AM
59flatbedford's Avatar
59flatbedford
59flatbedford is offline
i have no ideal because i just swaped in a sixty one frame. If i was you just cut the rivets out of the one in the 62 frame that you said you had in another post and bolt it in to your frame. Not like this is going to be exactly factory anyway so use whats available.
Old 03-31-2010, 11:15 AM
montego69's Avatar
montego69
Differences
The 60-65 frame has an incline right at that crossmember' location so the crossmember is a parallelogram when viewed from the side. The 60's frame is straight so the crossmember (or crossmembers) when viewed from the side would be a rectangle.
Old 03-31-2010, 11:35 AM
59flatbedford
hmm. i havent looked at my frame for a really long time but i though that the were pretty much straight and flat on both of them when i did my swap. Both these trucks used the same transfer case (i think) though so it should bolt to either cross-member(i think again). maybe post some picture of the one you have to refresh my memory a little. Because i think i still have a extra out of a 62.
Old 03-31-2010, 11:56 AM
montego69's Avatar
montego69
I put two pictures in my gallery. The only one that I had that showed the 62's chassis is looking from the back passenger side toward the front. If you look at the upper right side of the picture, you can see how the chassis slopes downward about 2 inches. That slope starts at the back edge of the crossmember and ends just ahead of the transfer case crossmember.
The 60's chassis is a straight line almost completely from front to back. The only place it dips is at the radiator support.
Nick
https://www.ford-trucks.com/forums/p...054345&thumb=1
Old 03-31-2010, 01:07 PM
59flatbedford
hmm im going to have to look at my frame next time im home. But at any rate i still dont know why you wouldnt be able to but the 62 crossmember in the 60 frame. You might have to trim just a little but i dont see why it wouldn't work.
Old 03-31-2010, 01:40 PM
montego69's Avatar
montego69
pictures tell a thousand words
I know I can cut and weld the newer crossmember and make it fit. I was really wanting to see what the factory setup looked like before just taking a stab at it.
I'm going to take a better picture of the '62's chassis tonight and post tomorrow. From the side, the slope is significant.
Nick
Old 04-01-2010, 07:52 AM
montego69's Avatar
montego69
New Gallery Pics of 1962 4X4 Chassis
I got 4 new pictures loaded into my gallery. They are views of the transfer case crossmember. You'll be able to see that the transfer case crossmember is completely mounted in the sloping area of the chassis. The 1960's chassis is straight through the same section. The frame overall c-channel heights are also different.
Like I said earlier, it would be real cool to see what a 57-60's frame/crossmember looks like in that area before I got all wild with the torch and welder.
Nick
Last edited by montego69; 04-01-2010 at 07:57 AM. Reason: trying to insert pictures...
Old 04-01-2010, 08:34 AM
3414's Avatar
3414
3414 is offline
If I get a chance I will crawl under one of my 4x4s (60 & 59) this weekend and see if I can get a picture for you.
Old 04-01-2010, 09:51 AM
montego69's Avatar
montego69
3414,
I greatly appreciate it.
Thanks,
Nick
Old 04-05-2010, 09:23 AM
3414's Avatar
3414
3414 is offline
Have a few pictures for you, not very good, as I could not get in a good position to take them. The 60 has a very different setup than that of the 62 in your picture. It looks like the 60 has two crossmembers, and brackets that support the transfer case bolt to these crossmembers.
[/IMG]
[/IMG]
[/IMG]
I have some more if these are not enough.
Old 04-05-2010, 09:26 AM
3414's Avatar
3414
3414 is offline
Well, that did not seem to work. I have them in my album titled grey pickup.
Old 04-05-2010, 10:18 AM
montego69's Avatar
montego69
pictures
Those are exactly what I needed! I GREATLY appreciate it.
If I can be of any help, don't hesitate to ask.
Nick
Quick Reply: 1957-1960 4X4 Spicer 24 Mount and Crossmember
