lighting
Old Apr 20, 2010 | 01:50 PM
chicagodragon's Avatar
chicagodragon
lighting
i have a 97 expedition. first, the truck did not come with lights in the bumper, is the wireing there? also, the running board lights dont work, i checked fuses,bulbs, etc... is there something i am missing, or a common fix?
Old Apr 21, 2010 | 07:06 AM
c_hohensee's Avatar
c_hohensee
As for the lights in the bumper, in 98 the wiring was there and all you needed was the lights and a different headlight switch. So I expect the same would be true of a 97. On the issue of the running board lights I have not had any experience working on them as mine have always worked.
Old Apr 21, 2010 | 12:12 PM
alloro's Avatar
alloro
Originally Posted by chicagodragon
the running board lights don't work
There's a relay in the under dash fuse box that turns off the running board lights after a door has been open for 45 minutes to save battery power. Surprisingly, they call this the battery saver relay. If this relay is no good or not turning on, then the running board lights won't work. Just a thought...
Old Apr 21, 2010 | 12:47 PM
chicagodragon
what position is it in?
Old Apr 21, 2010 | 12:48 PM
chicagodragon
the inside and running board lights are on different relays?
Old Apr 21, 2010 | 09:28 PM
alloro's Avatar
alloro
Yes, the Interior lamp relay is #1 top left. The Battery saver relay is #2 and is directly below the #1 Interior lamp relay.
2004f250superduty
Nov 4, 2013 11:40 AM
abyars111
Nov 12, 2012 09:18 AM
armour01
2004 - 2008 F150
Oct 16, 2012 02:11 AM
blackford97
Sep 5, 2011 10:28 PM
skip hatfield
2004 - 2008 F150
Mar 17, 2010 02:02 AM
